Hi, I am new to Duplicati, moving from Crashplan. I would like to duplicate the setup I have, which is each device on local LAN backing up for a file server. Basically a windows 7 PC that has a USB SATA drive plugged in.
So each client will back up to that drive.
Do I have to have a named folder for each client, or can I just use the root folder F:
Can I rotate the drive, as the client is pointing to the root it will simply see a blank empty backup the next time it runs and does a complete backup.
The reason for swapping drives, is in case house burns down and or a drive dies.
Duplicati works very hard to avoid storing data again if it’s already stored, even slicing files into blocks.
It has a database which is a local cache of certain destination data. Discrepancies will cause problems.
What I usually hear people wanting to do is to mirror the backup elsewhere. You can search the forum.
Because yours sounds like a manual backup after a drive carry, possibly you can have a job per drive.
Once you settle on what gets backed up, you can export the job then import to change the destination.
Guarding against wrong-drive-plugged-in is an issue, but Google found some discussion and answers.
