Just wondering if it’s possible to restore my duplicati files backed up to my OneDrive account to a different PC that I might be using at the time? I’m not meaning enabling remote access to my duplicati PC but using an entirely separate PC. I’m finding that exporting a backup configuration from the first PC to the second PC takes me into a backup sequence, not a restore.
Yes. From the main menu go to “Restore” then select “Direct restore from backup files …”. You’ll have to enter your OneDrive auth info but from there you should be able to select what files are to be restored and to where you want them saved.
Perfect, thank you. So obvious when it’s explained!
Glad I could help. (I went ahead and flagged my post as the solution, so please let me know if you disagree.)
