Hello. I wanted to check if it is possible to configure a restore periodically, I work in a company with several stores and I wanted to resend the backups made in these stores to the Matriz store server at the end of the day, would it be possible
As far as I know this is not possible with the standard Duplicati web UI and scheduler. You should be able to do it using Duplicati.CommandLine.exe and the OS scheduler of your choice (cron, Task Scheduler, etc).
