I been seeing the following for the last 10 days. What’s wrong? How do I fix it?
Feb 15, 2021 6:01 PM: Failed while executing “Backup” with id: 9
System.Security.Cryptography.CryptographicException: Invalid header marker —> System.IO.InvalidDataException: Invalid header marker
at SharpAESCrypt.SharpAESCrypt.ReadEncryptionHeader(String password, Boolean skipFileSizeCheck)
at SharpAESCrypt.SharpAESCrypt…ctor(String password, Stream stream, OperationMode mode, Boolean skipFileSizeCheck)
at Duplicati.Library.Encryption.AESEncryption.Decrypt(Stream input)
at Duplicati.Library.Encryption.EncryptionBase.Decrypt(Stream input, Stream output)
at Duplicati.Library.Main.BackendManager.<>c__DisplayClass36_0.b__0()
at System.Threading.Tasks.Task.Execute()
at Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()
at Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)
at Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBacked, Boolean forceCompact, BackendManager sharedManager)
at Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)
at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
