I’m experiencing the same problem. What have I do to?
Failed: Invalid file checksum
Details: CG.Web.MegaApiClient.DownloadException: Invalid file checksum
in Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()
in Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)
in Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBackend, Boolean forceCompact, BackendManager sharedManager)
in Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)
in Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()
--- Fine traccia dello stack da posizione precedente dove è stata generata l'eccezione ---
in System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
in CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
in Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result)
in Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
Log data:
2023-01-13 13:34:51 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat
System.IO.IOException: Il processo non può accedere al file '\\?\C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat' perché è in uso da un altro processo.
in System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
in System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
in System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
in Duplicati.Library.Common.IO.SystemIOWindows.FileOpenRead(String path)
in Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.<>c__DisplayClass1_0.<<Run>b__0>d.MoveNext()
2023-01-13 13:34:51 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat.LOG1
System.IO.IOException: Il processo non può accedere al file '\\?\C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat.LOG1' perché è in uso da un altro processo.
2023-01-13 13:34:51 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat.LOG2
System.IO.IOException: Il processo non può accedere al file '\\?\C:\Users\user\AppData\Local\Packages\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\Settings\settings.dat.LOG2' perché è in uso da un altro processo.
[MEGACUT]
