I want to install duplicati 2.0 on a raspberry pi 3b+ (with Rasbian buster lite).
I follow the instructions under duplicati.readthedocs.io/en/latest/02-installation/ as described under Raspbian 9. Because I use Rasbian Buster, I changed the word “debian” to “buster”.
But this doesn’t work, if I use something like sudo systemctl enable duplicati.service
, there is the following error message: Failed to enable unit: Unit file duplicati.service does not exist.
Yes, I think, I didn’t install duplicati. But how to install, it’s not described under duplicati.readthedocs.io/en/latest/02-installation/
How can I install the .deb file which is given on the download site?
If you need some more information, please write it
