Inline help accuracy... and translations
Hi
Sometimes we read in inline help/description for an option some text that refers to remote data, e.g.
By default, the last fileset cannot be removed. This is a safeguard to make sure that all remote data is not deleted by a configuration mistake. Use this option to disable that protection, such that all filesets can be deleted.
Does this also applies to local destination, in which case wouln’t we better read
By default, the last fileset cannot be removed. This is a safeguard to make sure that all data is not deleted in the destination by a configuration mistake. Use this option to disable that protection, such that all filesets can be deleted.
or better worded in perfect English?
Thanks
