First, let me start with the solution to my issue. Not sure it will work long term, but my backup after doing it took 19 minutes:
[root@voyageur Duplicati]# sqlite3 QFUVPZGKBK.sqlite
SQLite version 3.7.17 2013-05-20 00:56:22
Enter “.help” for instructions
Enter SQL statements terminated with a “;”
sqlite> pragma optimize;
sqlite> analyze;
sqlite> .exit
The problem? My blocksize was set to 100kb and I increased it without to 5Mb and the backups did work but they seemed to take increasingly longer and longer to finish. Since the option says you can’t change it, I decided to export the backup json, delete the backup files, and the database and start over.
When I did that, I think that first backup took ~5 hours. When I did the next backup, it was 8 hours. Today I did the pragma optimize; analyze; and the backup took just 19 minutes.
While I don’t know if I continue to expect this performance, but it is clear to me that this did something not normally done by a regular backup, even starting from an initial database.
Question: Is there any issue with performing these on a periodic basis? From what I can see, it would be a benefit to performance by doing this before any operation and especially before starting some operations like say compaction. I’m not a DB expert, but perhaps this is worthy of a backup configuration option so people could choose to “optimize” before starting.
Now, I’m not running the latest version so perhaps this has already been addressed. i’m running Version: 2.0.7.1 (2.0.7.1_beta_2023-05-25)
Answer: pragma optimize doesn’t yet exist IF Duplicati is using the systems’ sqlite libraries and not its’ own. the OS here is (due to be replaced I know) CentOS 7
Current Beta (and many prior) ship only a Windows SQLite. On Linux, it uses the system copy.
This is (I think) changing with current Canary, although I don’t know for sure if change will stay:
Feel free to test Canary if you like, but note that they’re first exposures of new fixes and bugs.
Solidify SQLite dependencies #4024 discusses the drawback of running on a system’s SQLite. Current emerging direction of Duplicati is fewer dependencies. Doesn’t even need mono either.
