Just tried to get a bug report again, this time with .123 - got another error that mentioned disk space, but that is fine, did notice an issue with memory which I sorted, but it’s still the same:
10 Jul 2025 09:47: Failed while executing CreateReport "MAGGIE-Local_Backup" (id: 5)
Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 13: 'database or disk is full'.
at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteNonQuery()
at System.Data.Common.DbCommand.ExecuteNonQueryAsync(CancellationToken cancellationToken)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQueryAsync(SqliteCommand self, Boolean writeLog, String cmd, Dictionary`2 values, CancellationToken cancellationToken)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQueryAsync(SqliteCommand self, String cmdtext, CancellationToken cancellationToken)
at Duplicati.Library.Main.Database.LocalBugReportDatabase.Fix(CancellationToken token)
at Duplicati.Library.Main.Operation.CreateBugReportHandler.RunAsync()
at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, Func`3 method)
at Duplicati.Library.Main.Controller.CreateLogDatabase(String targetpath)
10 Jul 2025 09:47: Error in worker
A couple of extra comments:
- The message that pops up showing there was an error, old an new UI, when you press the show log takes you to the job logs where this doesn’t exist as it’s in the main server logs under About.
- Has .123 release (maybe the previous ones as well) started using more memory? The server was fine after upgrading to .123 - it then did a backup and I got memory alerts and saw that Duplicati process were using far more than before the backup
