How do I totally delete duplicati on Ubuntu 18.04?
$ sudo apt purge duplicati
Will remove all the program files. You can then delete the Duplicati sqlite and other files by removing /root/.config/Duplicati
or /home/<username>/.config/Duplicati
as appropriate.
