I need help to do a scrip that connect a vpn automatically in Windows 10, to use it in duplicati.
How can I create a script that executes a vpn before making a copy?
I have a script created but it gives me error 703 when I run it in duplicati.
this is the script:
rasdial.exe “MYVPNNAME” “USERNAME” "PASSWORD"
I don’t know why it gives me that error if it works correctly on my computer.
If you can help me solve it, I would appreciate it very much.
Hello and welcome! I have combined your two posts into a single topic.
The script you wrote - does it work when you run it from a command prompt by itself? No error unless Duplicati tries running the script?
