As soon as I start a backup of a Hyper-V VM, I get this error:
System.IO.FileLoadException: Could not load file or assembly ‘AlphaVSS.Common, Version=1.4.0.0, Culture=neutral, PublicKeyToken=959d3993561034e3’ or one of its dependencies. The located assembly’s manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: ‘AlphaVSS.Common, Version=1.4.0.0, Culture=neutral, PublicKeyToken=959d3993561034e3’
at Duplicati.Library.Common.IO.VssBackupComponents…ctor()
at Duplicati.Library.Snapshots.HyperVUtility.d__17.MoveNext()
at Duplicati.Library.Snapshots.HyperVUtility.QueryHyperVGuestsInfo(Boolean bIncludePaths)
at Duplicati.Library.Modules.Builtin.HyperVOptions.RealParseSourcePaths(String& paths, String& filter, Dictionary2 commandlineOptions) at Duplicati.Library.Modules.Builtin.HyperVOptions.ParseSourcePaths(String[]& paths, String& filter, Dictionary2 commandlineOptions)
at Duplicati.Library.Main.Controller.SetupCommonOptions(ISetCommonOptions result, String& paths, IFilter& filter)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
I am on Duplicati Version 2.0.5.1_beta_2020-01-18
Im using the AlphaVSS Files 2.0.0 which I downloaded with Nuget and have put the 3 files (.net45 Version i think) to the alphavss folder and restartet.
It seems Duplicati still expects the old version of alphavss. Do I need to register somehting?
