HttpRequestException: Response status code does not indicate success: 400 (Bad Request)
I have 3 shares on a local NAS, each one of them has a backup job (run form a Windows10 system with 2.4.0.1) configured to its own folder on a WebDAV (Magenta) share . All three used to run without problems for months. Today two of them are still running OK, while one spits out this “Bad request”. Connection test is OK.
Here is the list of warnings (I deleted majority of same type warnings)
2026-11-29 21:37:55 +01 - [Warning-Duplicati.Library.Main.Backend.DatabaseCollector-FlushingMessagesToLog]: Operation: list File: Result: [
{“IsFolder”:false,“LastAccess”:“2021-01-26T12:24:11+01:00”,“LastModification”:“2021-01-26T12:24:11+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-b05c9ce205fa54716b8521d360f672d9f.dblock.zip.aes”,“Size”:52472397,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2019-07-20T19:28:04+02:00”,“LastModification”:“2019-07-20T19:28:04+02:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-i956c8c1ee66f46b6b25757ad00abbf8c.dindex.zip.aes”,“Size”:18397,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2021-06-13T14:29:47+02:00”,“LastModification”:“2021-06-13T14:29:47+02:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-i5647f397da4a4e14b3a67f49bc6e3271.dindex.zip.aes”,“Size”:18397,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2020-07-06T19:39:43+02:00”,“LastModification”:“2020-07-06T19:39:43+02:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-b5478d0afe54445dd8663a6627791cb68.dblock.zip.aes”,“Size”:52417565,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-27T12:21:11+01:00”,“LastModification”:“2026-11-27T12:21:11+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-b16317e8145474706ba0b27c84dacf923.dblock.zip.aes”,“Size”:5069,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-27T12:21:11+01:00”,“LastModification”:“2026-11-27T12:21:11+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-i20ba46defb8145449692d46ae366e9e4.dindex.zip.aes”,“Size”:1133,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-27T12:21:13+01:00”,“LastModification”:“2026-11-27T12:21:13+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-20261127T112000Z.dlist.zip.aes”,“Size”:1957949,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-29T16:53:24+01:00”,“LastModification”:“2026-11-29T16:53:24+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-baee00a6d9aca458faab8c90b8ea144da.dblock.zip.aes”,“Size”:520189,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-29T16:53:25+01:00”,“LastModification”:“2026-11-29T16:53:25+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-iea38dd510a5a4da78aef8ee999a8fe54.dindex.zip.aes”,“Size”:1949,“IsArchived”:false},
{“IsFolder”:false,“LastAccess”:“2026-11-29T16:53:27+01:00”,“LastModification”:“2026-11-29T16:53:27+01:00”,“Created”:“0001-01-01T00:00:00”,“Name”:“duplicati-20261129T155204Z.dlist.zip.aes”,“Size”:1958013,“IsArchived”:false}
Operation: delete File: duplicati-i921150f6cc3b47489c2800432e805be6.dindex.zip.aes.part Result: System.Net.Http.HttpRequestException: Response status code does not indicate success: 400 (Bad Request).
at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
at Duplicati.Library.Backend.WEBDAV.<>c__DisplayClass42_0.<b__0>d.MoveNext()
— End of stack trace from previous location —
at Duplicati.Library.Utility.Utility.WithTimeout(TimeSpan timeout, CancellationToken token, Func2 func) at Duplicati.Library.Backend.WEBDAV.DeleteAsync(String remotename, CancellationToken cancelToken) at Duplicati.Library.Main.Backend.BackendManager.DeleteOperation.ExecuteAsync(IBackend backend, CancellationToken cancelToken) Operation: delete File: duplicati-i921150f6cc3b47489c2800432e805be6.dindex.zip.aes.part Result: System.Net.Http.HttpRequestException: Response status code does not indicate success: 400 (Bad Request). at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode() at Duplicati.Library.Backend.WEBDAV.<>c__DisplayClass42_0.<<DeleteAsync>b__0>d.MoveNext() --- End of stack trace from previous location --- at Duplicati.Library.Utility.Utility.WithTimeout(TimeSpan timeout, CancellationToken token, Func2 func)
Is there anything I can do to narrow down the reason for the failure?
