I’m still running version 2.0.6.3_beta_2021-06-17 on an Ubuntu Server. Since it’s quite old, I’m wondering if I can update it straight to 2.1.0.4 or if there are some additional steps I need to take.
Thanks
Thanks
The upgrade is automatic, so there should be no additional steps besides installing the new version. The first run will update databases and leave a copy with a timestamp in case you need to downgrade.
However, the new version changes quite a few things that may impact you:
mono requiredmono packages after installing 2.1.0.4duplicati-client tool no longer works, but you can use ServerUtil for some of the tasks.
