after reading a lot here (and learning a lot :-), I have some questions
because I have to use a (very) slow connection between frontend and backend:
(The initial backup is transfered by external disk from frontend to backend)
How to reduce the communication and data transfer to a minimum?
Due to the fact that I have full access to both sides, it should be no
security to run Duplicati on the backend (Asustor NAS -> it is already there
How can I do a backend verification and let the frontend know, everything fine?
Or at least let the backend create the hashes for verification?
(Should I split this into two threads?)
Thank you all for your great work and support!
Ingo
