usually they are temporary files, locked files etc.
Windows machine.
Thanks!
Windows machine.
Thanks!
Hello, yes you can add an exclusion filter to skip files that start with “~”. Edit your backup job and on Page 3 expand the Filters section. Click the three dot menu on the side and click “Edit as text” and add this line:
This is a regular expression that matches files (not folders) that start with a tilde character.
Click Save on Page 5 to save the changes to your backup job.
Hope this helps.
It helps me a lot!
But I would like to not backup files starting with “~$”. And I can’t figure out the regex code.
is not working. Also editors like https://regexr.com/ could not help me, as I could not reproduce the result of your regex-code.
I would be very happy about any help!
Btw:
The aim is to exclude locked files in Windows. So the user and I as an Admin will not get an Warning Message/E-Mail, if a document is opened.
PS: I am a real beginner in regex. Sorry for that. And for several hours I have not been able to solve this problem.
Try putting a single backslash in front of the $
. That character has special meaning in regex so if you want it to match literally you have to escape it with a backslash.
Hope this helps!
Thank you! This works perfectly!
