How to MySQL Backup
Hello, I just installed duplicati I wanted to know if it is possible to make backups of MySQL databases
I need to backup multiple local and remote MySQL servers
I’m using duplicati on linux
Hello
As far as I know, there is nothing that allows to do online backup of Mysql databases under Linux. You’ll need a pre-run script to either export the database and backup the dump, or stop the database (obviously in this case you’ll need also a post-run script to restart it).
