How to fix missing file at the location
I got error about missing file:
LimitedErrors: [ 2022-10-17 12:33:33 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-8c04ae0b5e344453bce4594eab3a0ab3.dblock.zip.aes ]
My original data are still intact, is there a way how to tell duplicati to just re-upload impacted files?
Looks like the error is only when removing old files, but that still doesn’t look well, even if the file is not needed anymore, the fact it was missing (and thus my backup some days ago would be unreliable) is disturbing…
Error appeared both today and yesterday, same file.
try to use purge-broken-files.
Yup, looks like it worked, thanks :slight_smile:
