I have a number of backups, with version history of about 2 years.
Now I want to “duplicate” this backups into the cloud.
So I have Backup A, some sources, target a local DIR and I want a SECOND Backup with the same sources and the target should be a Cloud BUT: as first step I want to copy the local backup-files into the cloud.
So after this step a Backup A-1 should exists with the history aso. and a local DIR as target and a Backup A-2 sould exists with the same history aso. and a cloud DIR as target.
Same for Backup B, C, D, E, F, …
What is the easiest way to do this in duplicati for 8 to 10 backup jobs?
