Hi
I would like to backup to nextcloud via webDAV but in duplicati when i try to setup webDAV i get the following error
Failed to connect: The remote name could not be resolved: ‘https’
Hi
Hello,
I have several Duplicati installations backing up to NextCloud. A typical setup would look like this:
Adding https:// to the server is not necessary, as it will be added automatically if you check the “Use SSL” option.
The path on the server will always start with “remote.php/webdav” and will be followed by the name of the folder where your backup will be stored. So if you wanted to put it in a folder called “backups” it would look like this:
The username and password should be self explanatory.
