How to completely uninstall Duplicati on macOS
I installed Duplicati on macOS Sierra and want to remove it. I cannot find any instructions on the main site or in this forum.
It appears it installs some web service. If I must drag the App from Applications folder, does that remove everything?
Simply drag /Applications/Duplicati.app to the trash bin, that should remove everything except your backup configurations.
The configurations are stored in ~/.config/Duplicati, simply remove that folder as well, and it is all gone.
And how about the same instructions for windows server? Including removing the service and all files?
