Hi
I run Checkmk Raw in a Docker container and try to backup it using Duplicati. What is the best way to backup Checkmk in this scenario?
Currently I am mounting the /omd/sites directory into the container using the -v /data/cmk/monitoring:/omd/sites
parameter as documented here: Installation als Docker-Container
I use Duplicati to backup the data at /data/cmk/monitoring
on a daily basis. I assume this is basically enough to backup Checkmk running in Docker since I can stop/remove the container and start it again and everything is still in place. However sometimes, I get such kind of errors from Duplicati when it tries to backup the files (while Checkmk is also running of course):
2023-12-12 00:00:08 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for "/host/mnt/volume1/data/docker/volumes/check-mk-raw/omd/sites/cmk/var/pnp4nagios/spool/perfdata.1702335593", storing empty metadata
UnixSupport.File+FileAccesException: Unable to access the file "/host/mnt/volume1/data/docker/volumes/check-mk-raw/omd/sites/cmk/var/pnp4nagios/spool/perfdata.1702335593" with method llistxattr, error: ENOENT (2)
at UnixSupport.File.GetExtendedAttributes (System.String path, System.Boolean isSymlink, System.Boolean followSymlink) [0x00087] in <3a2c307381104a73ba105ad3712d666f>:0
at Duplicati.Library.Common.IO.SystemIOLinux.GetMetadata (System.String file, System.Boolean isSymlink, System.Boolean followSymlink) [0x0000d] in <6e4f34e913fd4d89b628a5a76045f19c>:0
at Duplicati.Library.Snapshots.NoSnapshotLinux.GetMetadata (System.String localPath, System.Boolean isSymlink, System.Boolean followSymlink) [0x00000] in <acb4fdca179441ff87fffb9a1b9a62c8>:0
at Duplicati.Library.Main.Operation.Backup.MetadataGenerator.GenerateMetadata (System.String path, System.IO.FileAttributes attributes, Duplicati.Library.Main.Options options, Duplicati.Library.Snapshots.ISnapshotService snapshot) [0x0001b] in <e60bc008dd1b454d861cfacbdd3760b9>:0
2023-12-12 00:00:08 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /host/mnt/volume1/data/docker/volumes/check-mk-raw/omd/sites/cmk/var/pnp4nagios/spool/perfdata.1702335593
System.IO.FileNotFoundException: Could not find file "/host/mnt/volume1/data/docker/volumes/check-mk-raw/omd/sites/cmk/var/pnp4nagios/spool/perfdata.1702335593"
File name: '/host/mnt/volume1/data/docker/volumes/check-mk-raw/omd/sites/cmk/var/pnp4nagios/spool/perfdata.1702335593'
at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <d13c8b563008422a8c5aaec0a74089cc>:0
at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) [0x00000] in <d13c8b563008422a8c5aaec0a74089cc>:0
at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare)
at System.IO.File.Open (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) [0x00000] in <d13c8b563008422a8c5aaec0a74089cc>:0
at Duplicati.Library.Snapshots.SnapshotBase.OpenRead (System.String localPath) [0x00000] in <acb4fdca179441ff87fffb9a1b9a62c8>:0
at Duplicati.Library.Main.Operation.Backup.FileBlockProcessor+<>c__DisplayClass1_0.<Run>b__0 (<>f__AnonymousType8`2[<Input>j__TPar,<StreamBlockChannel>j__TPar] self) [0x00217] in <e60bc008dd1b454d861cfacbdd3760b9>:0
Seems like some files are in use or not available anymore when Duplicati tries to backup them.
I am thinking of the following options:
- Should I exclude some directories/files from the Duplicati backup job?
- Should I play around with options like this in Duplicati? Advanced Options - Duplicati 2 User's Manual
- Should I rather use the built-in backup/restore feature of Checkmk as described here? Backups - Daten sichern und wiederherstellen
How can I address such situations in Duplicati in general?
Any advice is appreciated.
