How to add to existing set of backup sources?
Just installed duplicati and am moving toward full usage - I start with a small set of directories to backup. Then I’ll want to add to that set. But I see no obvious way to do that…
To be more specific, I’m backing up 3 dirs of 20 in a larger dir. I will eventually want to back them all up. Logically that’s just adding to the set already defined, but how do I do this?
Thanks!
And the answer is…
“edit” the configuration - using the dropdown next to the backup config name on the interface home page!
[Figured this out shortly after my original post, which I don’t yet see how to edit or delete. Feel free to delete this if it is not likely to be useful to others. But really shouldn’ this common topic be covered in the docs? Might be helpful.]
