How do I uninstall Duplicati on Linux
I’m having trouble finding directions for how to remove Duplicati on Linux, specifically on a CentOS system. Anyone have a pointer to an accurate document?
Thanks
D
I’m guessing your best bet would be to wait for @hydrian or @Pectojin to see this post.
Hopefully we’ll be able to make a #howto topic once you’re taken care of.
If you just installed the rpm package it should be as easy as finding the package name and removing it (e.g. searching rpm -qa | grep 'duplicati')
The deb package installs it as just duplicati, so assuming it’s the same package name it’s just a matter of running
sudo yum remove duplicati
Where are the same instructions for windows server? Including removing the service and all files?
Good question - I don’t think there are any yet. :slight_smile:
I’ve made a stub post for a central place to record this information, please check it out in a little bit (after we’ve had some time to actually put useful info in there). :slight_smile:
That’s great. Thanks.
But how does one actually do this?
I downloaded the windows version 2.0.3.3 and just installed with all the defaults. I would like to remove everything now. I am not sure if the defaults installed it as a server or not.
I’ve updated the #howto above, please see if that covers what you need.
