How Data Files Stored - External HD
Did pretty much a “plain vanilla” basic install of Duplicati, then saved my pictures to external hard drive. Backup is broken-down to many Zip folders.
Is there a way to store backup files visible on hard drive viewed in a Windows browser showing the pictures and documents identical to the source drive?
Welcome to the forum @GoodOleBob
No. Duplicati is a backup tool designed to backup historical versions compactly, allowing one to revert to earlier versions of files. It sounds like you could check:
Comparison of file synchronization software
Some can keep multiple versions of files (maybe not compactly). Others will not.
Many thanks for your reply.
It seems easiest that I step aside with any prior expectations of how, and enjoy Duplicati doing its good work in the best way possible. : )
 GoodOleBob
