Help with STATUS_IO_TIMEOUT Errors
Hello Community,
I´m desperatly struggling with Duplicati when trying to do Backups to an older DIY NAS I built. The Backup sometimes fails after 5 Minutes, sometimes after 1 hour with the following Error Messages in the Job:
  "Warnings": [
    "2026-10-25 12:06:43 +01 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerHandlerFailure]: Error in handler: Datei Schreiben mittels PutAsync fehlgeschlagen duplicati-b0f7569a6b5b64e1b9d2a86f8cad53812.dblock.zip.aes with status STATUS_IO_TIMEOUT\nUserInformationException: Datei Schreiben mittels PutAsync fehlgeschlagen duplicati-b0f7569a6b5b64e1b9d2a86f8cad53812.dblock.zip.aes with status STATUS_IO_TIMEOUT",
    "2026-10-25 12:06:44 +01 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeWhileActive]: Terminating 1 active uploads",
    "2026-10-25 12:06:44 +01 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Error in active upload: Cancelled",
    "2026-10-25 12:06:44 +01 - [Warning-Duplicati.Library.Main.Backend.BackendManager-BackendManagerShutdown]: Backend manager queue runner crashed\nAggregateException: One or more errors occurred. (Datei Schreiben mittels PutAsync fehlgeschlagen duplicati-b0f7569a6b5b64e1b9d2a86f8cad53812.dblock.zip.aes with status STATUS_IO_TIMEOUT)"
    "2026-10-25 12:06:44 +01 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\nUserInformationException: Datei Schreiben mittels PutAsync fehlgeschlagen duplicati-b0f7569a6b5b64e1b9d2a86f8cad53812.dblock.zip.aes with status STATUS_IO_TIMEOUT",
    "2026-10-25 12:06:44 +01 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: Die Operation Backup ist fehlgeschlagen\nUserInformationException: Datei Schreiben mittels PutAsync fehlgeschlagen duplicati-b0f7569a6b5b64e1b9d2a86f8cad53812.dblock.zip.aes with status STATUS_IO_TIMEOUT"
The Job backups MP3 files from an SMB share to the target SMB share.
I already reduced the “asynchronous-upload-limit” to 2, and the “read-write-timeout” to 5 minutes, but the error still happens.
Could it be that the NAS Hardware is simply to slow to handle the backups?
HP Microsserver N54L (AMD Turion(tm) II Neo N54L Dual-Core Processor)
8 GB DDR3
Intel Pro 1000 Dual NIC (1 used with 1gbit)
Open Media Vault (Current Version)
2x 2TB as RAID1
2x 8TB as RAID1
RAIDs were built with OMV, so It´s a software RAID
If there are any more details for debugging, I´ll be happy to provide them.
Thank you and a nice sunday,
Philipp
Hi @AdmiralRaccoon, welcome to the forum :waving_hand:
I think this might be the SMB error we have been tracking for a while:
Without the fix to report the real error code it gave the error in the issue “difference between bytes read and bytes written”.
What you report now is that it is actually a timeout, and it turns out there is a hard-coded 5s write chunk timeout. In normal operations the 5s should be plenty and that explains why we could not reproduce. On slower hardware there might be various stalls, and if one goes over the 5s mark, the transfer fails.
I will be fixing the timeout so it follows the “read-write-timeout” as it should logically have done.
In the meantime, maybe try setting asynchronous-upload-limit=1 could help. Additionally, throttling the upload speed might make the hardware less prone to latency spikes, as it can better handle the load.
Hello and thanks for the reply,
I don´t know if this has something to do with it:
Yesterday, I have rebuilt that RAID Array in OMV, and before that, I switched the BIOS Settings from the Server from RAID to AHCI (That was recommended somewhere).
Now I have done the same Backups again, they were much faster and finished without errors, even with the default settings.
I´ll keep an eye on it.
Thanks and have a nice day
