I set the block size to 64MB and the remote Volume Size to 1GB, why am I getting this fatal error every time?I’m using WebDAV for backup. Is this a cloud-based issue or a problem with my local settings?The following is the complete log.
“DeletedFiles”: 0,
“DeletedFolders”: 0,
“ModifiedFiles”: 0,
“ExaminedFiles”: 261,
“OpenedFiles”: 254,
“AddedFiles”: 254,
“SizeOfModifiedFiles”: 0,
“SizeOfAddedFiles”: 140365779026,
“SizeOfExaminedFiles”: 161053438657,
“SizeOfOpenedFiles”: 140365779026,
“NotProcessedFiles”: 0,
“AddedFolders”: 0,
“TooLargeFiles”: 0,
“FilesWithError”: 0,
“TimestampChangedFiles”: 0,
“ModifiedFolders”: 0,
“ModifiedSymlinks”: 0,
“AddedSymlinks”: 0,
“DeletedSymlinks”: 0,
“PartialBackup”: false,
“Dryrun”: false,
“MainOperation”: “Backup”,
“CompactResults”: null,
“VacuumResults”: null,
“DeleteResults”: null,
“RepairResults”: null,
“TestResults”: null,
“ParsedResult”: “Fatal”,
“Interrupted”: false,
“Version”: “2.2.0.0 (2.2.0.0_stable_2025-10-23)”,
“EndTime”: “2025-10-31T22:28:25.7186456Z”,
“BeginTime”: “2025-10-31T14:26:05.31563Z”,
“Duration”: “08:02:20.4030156”,
“MessagesActualLength”: 647,
“WarningsActualLength”: 8,
“ErrorsActualLength”: 2,
“Messages”: [
“2025-10-31 22:26:05 +08 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: 操作 Backup 已开始”,
“2025-10-31 22:26:10 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2025-10-31 22:26:16 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()”,
“2025-10-31 22:36:04 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b6f58c5fb03f042fb8899d63806101427.dblock.zip.aes (961.11 MiB)”,
“2025-10-31 22:36:08 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bb830359fac234d4dabfd8471fa591ddd.dblock.zip.aes (972.17 MiB)”,
“2025-10-31 22:36:10 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bd1540844f9ea44c4b35758410e4a65f2.dblock.zip.aes (970.48 MiB)”,
“2025-10-31 22:36:17 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b3b9aba10e4ea41f8b4354f32d97188d5.dblock.zip.aes (980.29 MiB)”,
“2025-10-31 22:48:06 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bd1540844f9ea44c4b35758410e4a65f2.dblock.zip.aes (970.48 MiB)”,
“2025-10-31 22:48:06 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i0d5f86351b0247fe94fd9d99275a5b24.dindex.zip.aes (3.98 KiB)”,
“2025-10-31 22:48:08 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i0d5f86351b0247fe94fd9d99275a5b24.dindex.zip.aes (3.98 KiB)”,
“2025-10-31 22:48:08 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b33c8898221464196b5e487101ae69065.dblock.zip.aes (995.64 MiB)”,
“2025-10-31 22:50:26 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b6f58c5fb03f042fb8899d63806101427.dblock.zip.aes (961.11 MiB)”,
“2025-10-31 22:50:26 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i7c0d4afd3ad14fc8820af50a70c21124.dindex.zip.aes (3.29 KiB)”,
“2025-10-31 22:50:29 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i7c0d4afd3ad14fc8820af50a70c21124.dindex.zip.aes (3.29 KiB)”,
“2025-10-31 22:50:31 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b7a73ebe6915548da84a987488281092a.dblock.zip.aes (962.03 MiB)”,
“2025-10-31 22:50:31 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bb830359fac234d4dabfd8471fa591ddd.dblock.zip.aes (972.17 MiB)”,
“2025-10-31 22:50:31 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i8de12b3b68ca4fd08f5fe8c03e088832.dindex.zip.aes (4.53 KiB)”,
“2025-10-31 22:50:33 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i8de12b3b68ca4fd08f5fe8c03e088832.dindex.zip.aes (4.53 KiB)”,
“2025-10-31 22:50:33 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b9e28d23f15a3428ca404c8d6c13822d9.dblock.zip.aes (1,002.56 MiB)”,
“2025-10-31 22:50:57 +08 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b3b9aba10e4ea41f8b4354f32d97188d5.dblock.zip.aes (980.29 MiB)”
“Warnings”: [
“2025-11-01 06:28:24 +08 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerHandlerFailure]: Error in handler: Error while copying content to a stream.\r\nHttpRequestException: Error while copying content to a stream.”,
“2025-11-01 06:28:24 +08 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeWhileActive]: Terminating 3 active uploads”,
“2025-11-01 06:28:24 +08 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Error in active upload: Cancelled”,
“2025-11-01 06:28:24 +08 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Terminating, but 2 active upload(s) are still active”,
“2025-11-01 06:28:24 +08 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: Terminating, but 1 active upload(s) are still active”,
“2025-11-01 06:28:25 +08 - [Warning-Duplicati.Library.Main.Backend.BackendManager-BackendManagerShutdown]: Backend manager queue runner crashed\r\nAggregateException: One or more errors occurred. (Error while copying content to a stream.)”
“Errors”: [
“2025-11-01 06:28:25 +08 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\r\nHttpRequestException: Error while copying content to a stream.”,
“2025-11-01 06:28:25 +08 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed\r\nHttpRequestException: Error while copying content to a stream.”
“BackendStatistics”: {
“RemoteCalls”: 293,
“BytesUploaded”: 136888860908,
“BytesDownloaded”: 0,
“FilesUploaded”: 268,
“FilesDownloaded”: 0,
“FilesDeleted”: 0,
“FoldersCreated”: 0,
“RetryAttempts”: 23,
“UnknownFileSize”: 0,
“UnknownFileCount”: 0,
“KnownFileCount”: 0,
“KnownFileSize”: 0,
“KnownFilesets”: 0,
“LastBackupDate”: “0001-01-01T00:00:00”,
“BackupListCount”: 0,
“TotalQuotaSpace”: 0,
“FreeQuotaSpace”: 0,
“AssignedQuotaSpace”: -1,
“ReportedQuotaError”: false,
“ParsedResult”: “Success”,
“BeginTime”: “2025-10-31T14:26:05.3158708Z”,
“Duration”: “00:00:00”,
“MessagesActualLength”: 0,
“WarningsActualLength”: 0,
“ErrorsActualLength”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
