Hello, I created a new backup job a few days ago, (Windows 10 PC to OneDrive V2) using Duplicati 2.0.4.5_beta_2018-11-28.
My backup finished today. After uploading, it verified some of the files as expected and when finished with that, Duplicati gave me an error. After reading the error, I googled about it and searched these forums and still don’t understand the problem. It seems to be something with the verification. I have ran the verification twice more, and get the same errors. I did a test restore of a file and that worked and the file checksum checks out.
Below is the error I got. I am wondering about the errors listed as: “Failed to process file …dblock.zip.aes” and “Value: A task was canceled.” I haven’t canceled the task as far as I know. Did OneDrive cancel the download during verification?
Any help would be greatly appreciated. I just want to know if my backup is safe. Thank you.
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 266
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 152364334413
SizeOfOpenedFiles: 0
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 2
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 2202
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Error
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 12/3/2018 20:42:46 (1543891366)
BeginTime: 12/3/2018 20:42:46 (1543891366)
Duration: 00:00:00.3906378
Messages: [
2018-12-03 20:42:34 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2018-12-03 20:42:40 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2018-12-03 20:42:43 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (145 bytes),
2018-12-03 20:42:44 -06 - [Information-Duplicati.Library.Main.Operation.BackupHandler-SkipUsnForVolume]: Performing full scan for volume "S:\",
2018-12-03 20:42:44 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: むかしむかし-be4d2be10db854663b2ebbb5858365b25.dblock.zip.aes (1.06 KB),
Warnings: [\*]
Errors: [
2018-12-03 20:51:51 -06 - [Error-Duplicati.Library.Main.Operation.TestHandler-RemoteFileProcessingFailed]: Failed to process file むかしむかし-bbb4897a42bf24292b9138e9e73901774.dblock.zip.aes,
2018-12-03 21:00:52 -06 - [Error-Duplicati.Library.Main.Operation.TestHandler-RemoteFileProcessingFailed]: Failed to process file むかしむかし-b8d3fe233e28947a18a4e01e264eada96.dblock.zip.aes
BackendStatistics:
RemoteCalls: 19
BytesUploaded: 2202
BytesDownloaded: 93095
FilesUploaded: 2
FilesDownloaded: 3
FilesDeleted: 2
FoldersCreated: 0
RetryAttempts: 8
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 145
KnownFileSize: 152390436957
LastBackupDate: 12/1/2018 19:40:11 (1543714811)
BackupListCount: 1
TotalQuotaSpace: 1131723882496
FreeQuotaSpace: 547411159292
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
DeleteResults:
DeletedSets: []
Dryrun: False
MainOperation: Delete
ParsedResult: Error
Duration: 00:00:00.4074074
Messages: [
Warnings: []
Errors: [
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: むかしむかし-20181202T014011Z.dlist.zip.aes
Value: [],
Key: むかしむかし-ide3694b75d9a44db9ddf4fa13a20aad2.dindex.zip.aes
Value: [],
Key: むかしむかし-i17749172140a47248667ec7cce79f5bd.dindex.zip.aes
Value: [],
Key: むかしむかし-bbb4897a42bf24292b9138e9e73901774.dblock.zip.aes
Value: [
Key: Error
Key: むかしむかし-b8d3fe233e28947a18a4e01e264eada96.dblock.zip.aes
Value: [
Key: Error
ParsedResult: Error
EndTime: 12/3/2018 21:00:52 (1543892452)
BeginTime: 12/3/2018 20:42:48 (1543891368)
Duration: 00:18:04.5883219
Messages: [
Warnings: []
Errors: [
ParsedResult: Error
BeginTime: 12/3/2018 20:42:34 (1543891354)
Duration: 00:18:18.4655877
Messages: [
Warnings:
Errors: [
