Help to configure duplicati with terabox
Hello.
I need to configure duplicati to backup my Terabox account, but I don’t know how to configure it. can you help me?
Thanks
Hi @Poloar, welcome to the forum :wave:
From what I can see, Terabox does not have a public API.
Without an API, 3rd party applications, such as Duplicati, cannot connect to it.
If an API exists, please correct me and post the link to the documentation.
First, that reads like you want to backup the Terabox account to somewhere else.
Is that actually what you mean? If you mean backup something TO Terabox, it’s a little easier, but probably still not easy. It might mean connecting a lot of software, unless they have something that can sync Duplicati local files to them for storage.
TeraBox Introduces Open Platform is possibly the announcement with link.
API integration document is programmer level information.
Terabox backend #8508 is rclone PR work hitting various bumps right now.
If it ever gets put in rclone, then Duplicati Rclone destination can build on it,
at least in that use case. We never got clarification on what this topic wants.
Putting it in Duplicati could likely be tried, but that doesn’t mean it should be.
Thanks for posting. I have created an issue for supporting Terabox.
Hi.
Do you know if it's already compatible with Terabox?
Please keep an eye on the issue above your post, if that is what you are asking for. Link again:
If you are seeking to backup your data now in TeraBox to somewhere else, that’s quite different.
