Hello
I would like some help understanding these 48 warnings I got after finishing the backup. There were no errors, but I don’t know what to do about the warnings in order to get a successful back up.
Thanks in advance.
- 2020-05-24 14:20:29 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\Satellite C55\AppData\Local\Packages\SpotifyAB.SpotifyMusic_zpdnekdrzrea0\SystemAppData\Helium\Cache\
- 2020-05-24 14:20:47 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\Satellite C55\AppData\Local\ElevatedDiagnostics\
- 2020-05-24 14:21:47 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\NTUSER.DAT
- 2020-05-24 14:21:47 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\ntuser.dat.LOG1
- 2020-05-24 14:21:47 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\ntuser.dat.LOG2
- 2020-05-24 14:22:00 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Roaming\Mozilla\Firefox\Profiles\duuxzufb.default-1578446814598\parent.lock
- 2020-05-24 14:22:18 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Temp\dup-8c51f958-0d08-43e4-941e-86255f8bc3ef
- 2020-05-24 14:22:19 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\Satellite C55\AppData\Local\Packages\SpotifyAB.SpotifyMusic_zpdnekdrzrea0\SystemAppData\Helium\Cache\
- 2020-05-24 14:22:19 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataGenerator.Metadata-MetadataProcessFailed]: Failed to process metadata for “C:\Users\Satellite C55\AppData\Local\Packages\SpotifyAB.SpotifyMusic_zpdnekdrzrea0\SystemAppData\Helium\Cache”, storing empty metadata
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\Settings\settings.dat
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\Settings\settings.dat.LOG1
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\Settings\settings.dat.LOG2
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\Settings\settings.dat
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\Settings\settings.dat.LOG1
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\Settings\settings.dat.LOG2
- 2020-05-24 14:22:26 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\AppData\CacheStorage\CacheStorage.edb
- 2020-05-24 14:22:27 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: C:\Users\Satellite C55\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\AppData\CacheStorage\CacheStorage.jfm
