help can you safely use 7-zip compression LZMA2? and how to enable this option?
I don’t believe the underlying 7-zip issues have been resolved so I would strongly recommend against it. I have a few older backups that started out using 7-zip then I change to zip and now most of the errors I get with those jobs are related to the old 7-zip content.
As far as I know there is currently no way to use LZMA2 with zip (though LZMA can be enabled with --zip-compression-method=LZMA
I’m also curious if and when this issue gets / is fixed. Also if it’s still broken, it should give clear indication, that it’s broken, and require something like --please-destroy-my-backups
parameter or something similar. I personally would prefer lzma2 / 7z / 7-zip compression.
