I’m using Duplicati - 2.0.2.8_canary_2017-09-20.
On the zip-compression-method option, I can’t use the Gzip.
Am I misconfigured something? It makes an error like below.
Fatal error
SharpCompress.Common.InvalidFormatException: Invalid compression method: GZip
at SharpCompress.Writers.Zip.ZipWriter.ToZipCompressionMethod(CompressionType compressionType)
at SharpCompress.Writers.Zip.ZipWriter.WriteToStream(String entryPath, ZipWriterEntryOptions options)
at Duplicati.Library.Compression.FileArchiveZip.CreateFile(String file, CompressionHint hint, DateTime lastWrite)
at Duplicati.Library.Main.Volumes.VolumeWriterBase.AddManifestfile()
at Duplicati.Library.Main.Volumes.VolumeWriterBase…ctor(Options options, DateTime timestamp)
at Duplicati.Library.Main.Volumes.FilesetVolumeWriter…ctor(Options options, DateTime timestamp)
