In the GUI running on Linux, under Advanced I click commandline. On the next page, I select “test” as the command, leave everything else as-is and then click ‘Run “test” Command Now’.
I get the following error message:
Running commandline entry
Finished!System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber (System.String str, System.Globalization.NumberStyles options, System.Number+NumberBuffer& number, System.Globalization.NumberFormatInfo info, System.Boolean parseDecimal) [0x00057] in :0
at System.Number.ParseInt64 (System.String value, System.Globalization.NumberStyles options, System.Globalization.NumberFormatInfo numfmt) [0x00014] in :0
at System.Int64.Parse (System.String s, System.IFormatProvider provider) [0x00008] in :0
at System.Convert.ToInt64 (System.String value) [0x0000c] in :0
at Duplicati.CommandLine.Commands.Test (System.IO.TextWriter outwriter, System.Action1[T] setup, System.Collections.Generic.List
1[T] args, System.Collections.Generic.Dictionary2[TKey,TValue] options, Duplicati.Library.Utility.IFilter filter) [0x0007f] in <71ed3aa6fd0e4ec4934b502e9e6ebc99>:0 at (wrapper delegate-invoke) System.Func
6[System.IO.TextWriter,System.Action1[Duplicati.Library.Main.Controller],System.Collections.Generic.List
1[System.String],System.Collections.Generic.Dictionary2[System.String,System.String],Duplicati.Library.Utility.IFilter,System.Int32].invoke_TResult_T1_T2_T3_T4_T5(System.IO.TextWriter,System.Action
1<Duplicati.Library.Main.Controller>,System.Collections.Generic.List1<string>,System.Collections.Generic.Dictionary
2<string, string>,Duplicati.Library.Utility.IFilter)
at Duplicati.CommandLine.Program.RunCommandLine (System.IO.TextWriter outwriter, System.IO.TextWriter errwriter, System.Action`1[T] setup, System.String[] args) [0x003fb] in <71ed3aa6fd0e4ec4934b502e9e6ebc99>:0
Return code: 100
FWIW, when I try manually running in a terminal, it asks for my encryption passphrase and then just sits there eating CPU indefinitely. The command I’m entering is:
duplicati-cli test “ssh://192.168.1.77:770//duplicati_data?auth-username=someone&auth-password=something&ssh-fingerprint=ssh-rsa%202048%205C%3A8E%3A33%3A8E%3A1C%3A3D%3AC1%3A5C%3A87%3AF1%3AF8%3A9B%3A44%3AC1%3A96%3A01”
I’ve also tried the above changing the // before the directory name to a single /, with the same results.
I’d appreciate help with either way of running the test. My goal, once I have a basic test command working, is to run it with the --full-remote-verification option, since I’ve had some problems with hash error messages showing up.
Thanks!
