I checked out the master branch and opened the Duplicati.sln file in Monodevelop. If I select Duplicati.GUI.TrayIcon and hit the play button next to the dropdown, I end up with a status of “Build: 0 errors, 13 warnings”. Unfortunately, in the Application Output window, I get some error messages. And I cannot load 127.0.0.1:8200 in my browser, it says it cannot connect. (I did turn of my non-dev instance.)
A browser window sometimes pops up with the correct url, but it can’t connect either.
Here’s the output I get:
Server has started and is listening on 127.0.0.1, port 8200
Gtk-Message: Failed to load module "atk-bridge"
Gtk-Message: Failed to load module "canberra-gtk-module"
Exception in Gtk# callback delegate
Note: Applications can use GLib.ExceptionManager.UnhandledException to handle the exception.
GLib.GException: Couldn't recognize the image file format for file '/home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/bin/Debug/SVGIcons/dark/normal-error.svg'
at Gdk.Pixbuf..ctor (System.String filename) [0x0006e] in <247d3298cc1240adb6e328c488f64545>:0
at Duplicati.GUI.TrayIcon.GtkRunner.GetIcon (Duplicati.GUI.TrayIcon.TrayIcons icon) [0x00158] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/GtkRunner.cs:301
at Duplicati.GUI.TrayIcon.GtkRunner.set_Icon (Duplicati.GUI.TrayIcon.TrayIcons value) [0x00008] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/GtkRunner.cs:312
at Duplicati.GUI.TrayIcon.TrayIconBase+<OnStatusUpdated>c__AnonStorey1.<>m__0 () [0x00059] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/TrayIconBase.cs:209
at Duplicati.GUI.TrayIcon.GtkRunner+<UpdateUIState>c__AnonStorey0.<>m__0 (System.Object sender, System.EventArgs arg) [0x00007] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/GtkRunner.cs:221
at Gtk.Application+InvokeCB.Invoke () [0x00000] in <e8d21baece374fadb4e2b3899720848c>:0
at GLib.Timeout+TimeoutProxy.Invoke (System.IntPtr data) [0x00000] in <940f51fcd0434c359bfa4fdc8e64ad03>:0
at GLib.SourceProxy.HandlerInternal (System.IntPtr data) [0x00000] in <940f51fcd0434c359bfa4fdc8e64ad03>:0
at GLib.ExceptionManager.RaiseUnhandledException (System.Exception e, System.Boolean is_terminal) [0x00000] in <940f51fcd0434c359bfa4fdc8e64ad03>:0
at Gtk.Application.gtk_main () [0x00000] in <e8d21baece374fadb4e2b3899720848c>:0
at Gtk.Application.Run () [0x00000] in <e8d21baece374fadb4e2b3899720848c>:0
at Duplicati.GUI.TrayIcon.GtkRunner.Run (System.String[] args) [0x0003b] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/GtkRunner.cs:198
at Duplicati.GUI.TrayIcon.TrayIconBase.Init (System.String[] args) [0x0003d] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/TrayIconBase.cs:78
at Duplicati.GUI.TrayIcon.GtkRunner.Init (System.String[] args) [0x00009] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/GtkRunner.cs:183
at Duplicati.GUI.TrayIcon.Program.RealMain (System.String[] _args) [0x00536] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/Program.cs:239
at System.Reflection.MonoMethod.InternalInvoke (System.Reflection.MonoMethod , System.Object , System.Object[] , System.Exception& ) [0x00000] in <2c1e745790d7412db8f8fdd869d65478>:0
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00032] in /run/build/mono/mcs/class/corlib/System.Reflection/MonoMethod.cs:305
at System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) [0x00000] in /run/build/mono/mcs/class/referencesource/mscorlib/system/reflection/methodbase.cs:229
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String[] args) [0x0000e] in /home/username/dev/tools/duplicati/Duplicati/Library/AutoUpdater/UpdaterManager.cs:996
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecentSpawn (System.Reflection.MethodInfo method, System.String[] cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x0002b] in /home/username/dev/tools/duplicati/Duplicati/Library/AutoUpdater/UpdaterManager.cs:1079
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecent (System.Reflection.MethodInfo method, System.String[] cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x00027] in /home/username/dev/tools/duplicati/Duplicati/Library/AutoUpdater/UpdaterManager.cs:1072
at Duplicati.GUI.TrayIcon.Program.Main (System.String[] args) [0x0001d] in /home/username/dev/tools/duplicati/Duplicati/GUI/Duplicati.GUI.TrayIcon/Program.cs:62
I’m running Ubuntu 16.04. I did start from a server image, and manually chose everything I wanted installed. So I could easily be missing something the normal desktop distribution has.
$ sudo apt install gtk-sharp2
Reading package lists... Done
Building dependency tree
Reading state information... Done
gtk-sharp2 is already the newest version (2.12.45-0xamarin9+ubuntu1604b1).
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
I searched on a couple key words and found this:
$ sudo apt search bridge | grep atk
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libatk-adaptor/xenial,now 2.18.1-2ubuntu1 amd64 [installed,automatic]
libatk-adaptor-data/xenial,xenial 2.18.1-2ubuntu1 all
libatk-bridge2.0-0/xenial,now 2.18.1-2ubuntu1 amd64 [installed,automatic]
libatk-bridge2.0-dev/xenial 2.18.1-2ubuntu1 amd64
libatk-wrapper-java/xenial,xenial 0.33.3-6 all
libatk-wrapper-java-jni/xenial 0.33.3-6 amd64
$ sudo apt search canberra | grep gtk
libcanberra-gtk-common-dev/xenial,xenial 0.30-2.1ubuntu1 all
libcanberra-gtk-dev/xenial 0.30-2.1ubuntu1 amd64
libcanberra-gtk-module/xenial,now 0.30-2.1ubuntu1 amd64 [installed]
libcanberra-gtk-module-dbg/xenial 0.30-2.1ubuntu1 amd64
libcanberra-gtk0/xenial,now 0.30-2.1ubuntu1 amd64 [installed,automatic]
libcanberra-gtk0-dbg/xenial 0.30-2.1ubuntu1 amd64
libcanberra-gtk libraries detached debugging symbols
libcanberra-gtk3-0/xenial,now 0.30-2.1ubuntu1 amd64 [installed,automatic]
libcanberra-gtk3-0-dbg/xenial 0.30-2.1ubuntu1 amd64
libcanberra-gtk3-dev/xenial 0.30-2.1ubuntu1 amd64
libcanberra-gtk3-module/xenial,now 0.30-2.1ubuntu1 amd64 [installed]
libcanberra-gtk3-module-dbg/xenial 0.30-2.1ubuntu1 amd64
It looks like some of the -dev packages are not installed. Would those be required?
I am not familiar with libcanberra, so I can’t help there. Does it work if you install Duplicati from the .deb package? If so, then I would assume that it pulls the correct depdencies. Running from your own build should then work the same.
