Running Duplicati 2.0.6.3_beta_2021-06-17
I have some problems with Google Drive/Team Drive.
Want to use Team Drive as destination, but if I add any PATH on Drive or Shared Drive, I get an error. I basically tried any possible way to add the folder name, like /test but if anything is written in path field the testing fails (tried many combinations, like \test \test //test/, etc.)
They all give me an error. If I leave the path empty, it works. But then Duplicati puts all the files in the root of the Shared Drive.
Any ideas?
System.Net.WebException: The remote server returned an error: (400) Bad Request.
at System.Net.HttpWebRequest.GetResponseFromData (System.Net.WebResponseStream stream, System.Threading.CancellationToken cancellationToken) [0x00146] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <2a3ee711c7c04f6c957360f2cf183a7f>:0
at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in <2a3ee711c7c04f6c957360f2cf183a7f>:0
at Duplicati.Library.JSONWebHelper.GetResponse (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x000c9] in <fd6b26d6c1004933aab594493968119c>:0
at Duplicati.Library.JSONWebHelper.ReadJSONResponse[T] (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x00000] in <fd6b26d6c1004933aab594493968119c>:0
at Duplicati.Library.JSONWebHelper.GetJSONData[T] (System.String url, System.Action`1[T] setup, System.Action`1[T] setupbodyreq) [0x00024] in <fd6b26d6c1004933aab594493968119c>:0
at Duplicati.Library.Backend.GoogleDrive.GoogleDrive+<ListFolder>d__42.MoveNext () [0x000fd] in <19fe1fc6864a43d3bde1faa83aaaa516>:0
at System.Collections.Generic.LargeArrayBuilder`1[T].AddRange (System.Collections.Generic.IEnumerable`1[T] items) [0x0003d] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Collections.Generic.EnumerableHelpers.ToArray[T] (System.Collections.Generic.IEnumerable`1[T] source) [0x00033] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x00018] in <798dd06330af4ca3886d7d2be5573af7>:0
at Duplicati.Library.Backend.GoogleDrive.GoogleDrive.GetFolderId (System.String path, System.Boolean autocreate) [0x0004c] in <19fe1fc6864a43d3bde1faa83aaaa516>:0
at Duplicati.Library.Backend.GoogleDrive.GoogleDrive.get_CurrentFolderId () [0x0000d] in <19fe1fc6864a43d3bde1faa83aaaa516>:0
at Duplicati.Library.Backend.GoogleDrive.GoogleDrive+<List>d__17.MoveNext () [0x00040] in <19fe1fc6864a43d3bde1faa83aaaa516>:0
at Duplicati.Library.Interface.BackendExtensions.TestList (Duplicati.Library.Interface.IBackend backend) [0x00017] in <fd3642a459884bd9a2412b4eda050109>:0
at Duplicati.Library.Backend.GoogleDrive.GoogleDrive.Test () [0x00000] in <19fe1fc6864a43d3bde1faa83aaaa516>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in <156011ea63b34859b4073abdbf0b1573>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00094] in <156011ea63b34859b4073abdbf0b1573>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x00289] in <156011ea63b34859b4073abdbf0b1573>:0
System.ObjectDisposedException: Cannot write to a closed TextWriter.
at System.IO.StreamWriter.Flush (System.Boolean flushStream, System.Boolean flushEncoder) [0x00008] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at System.IO.StreamWriter.Flush () [0x00006] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x003bc] in <156011ea63b34859b4073abdbf0b1573>:0
