Google account blocking (Need help understanding the problem)
This is a bit off topic, but your answers might help noobs like me.
About 12 days ago, I registered a separate new Google account to access Google Drive cloud storage (with a different phone number). I set up automatic backups to it via Duplicati, every 24 hours, the files are encrypted (the VPN was running all the time).
After 3 days, the account was blocked with a note:
“This account appears to have been created or used with numerous other accounts for purposes that violate Google’s policies. It could have been created by a computer program or a bot.”
The account was not restored on appeal. The bot replied that I definitely broke something.
“Unfortunately, access to your account cannot be restored. According to our verification, this account was used for purposes that violate Google policies.”
I want to know the following:
  1. What is a violation of the rules of Google with all of the above (in your opinion)?
  2. What does a backup to a third-party software repository look like without violations?
  3. What you need to know about the behavior of the Google bot in order not to get the same problem? (Important!)
  4. Which cloud services are better to use to set up automatic backup and forget about it for 2 years. (Important!)
Text translator used
If you try again, maybe use a residential IP (no VPN at first) and let the account sit for a bit before uploading backups.
I had a similar issue a while back when I made a second Google account just to store some shared project files. Everything seemed fine until I logged in from a different location (still on VPN), and boom—account locked. The appeal was a dead end, just like yours. What finally worked for me was using a non VoIP number for SMS verification when creating the account. Google seems to flag accounts without a “real” phone number, even if everything else is legit. A friend recommended Tardigrada for that, and I haven’t had issues since. Might be worth trying if you need another backup solution.
