Introduction
Duplicati is an open source backup application, which runs on your local machine, and encrypts data prior to uploading it. The user interface is web-based and allows you to control all the options offered by Duplicati, from a simple and intuitive interface.
This guide assumes you have already installed Duplicati, and are about to set up your very first backup.
1. The home screen
On the home screen, click the "Add backup" to get started.
Mobile devices and small screens.
On devices with small screens, the menu is located top-right, and needs an extra click to show.
2. Choose how to add the backup
On the initial page, we choose the default “Configure a new backup” and click the “Next” button.
3. Basic options
On the very first page, we need to choose a name for our backup. This can be anything you like, and is only used to find the backup later, in case you want to have many different backups.
The encryption methods are available from the dropdown with AES-256 pre-selected. Generally, you should encrypt your backups, but it is also possible to choose “No encryption” in case you are storing the files on a trusted location.
Rather than choosing a passphrase, you can click the “Generate” button and have a strong passphrase generated for you. If you generate a passphrase, make sure you write it down and store it in a safe place. If you lose this passphrase, you lose all access to your backup.
Please note: There are no options for recovering a lost passphrase!
Once you have filled in the fields as you like, click the next button, or use the navigation in the top to choose the next step.
4. Storage option
The next step is to choose where to store data. For this step, you need to have some information from your storage provider, such as a username and a password. If you have a network drive, or external hard-drive, you can also choose to store your data there. You will need to enter different values, depending on what storage provider you are using.
In this example, we are using a WebDAV based backend, which requires us to input a server name, a path on the server, as well as a username and password. If your storage provider has a Duplicati section, you can click the three dots to reveal a small menu that allows you to import a “connection url”. Likewise, you can create a “connection url” for others to use via the export menu.
The “Test connection” button ensures that the information is entered correctly, and that your machine can connect to the storage destination.
As before, you can use the “Next” button or the navigation line at the top to choose the next step.
5. Source data
In this step you must choose what files to make a backup of. Most users will only need to locate the desired folder in the tree, and check the desired folders. Subfolders to an included folder can be excluded by clicking the check mark. For advanced users, the three dots will enable a text display where each line is a folder or file to back up.
Exclusions based on attributes or file size can be configured under the “Exclude” section.
The filters section can be used to selectively exclude certain files or folders. You can read more about filters in the detailed explanation of how filters work.
5. Schedule runs
The schedule step lets you set how frequent the backup runs. You can disable the schedule such that you can manually choose when the backup runs. But rather than forgetting to run the backup, we recommend that you setup a regular schedule.
If your computer is off or Duplicati is not running, Duplicati will automatically run the backup the next time it is started.
6. More options
The final page lets you control how large files Duplicati will create on the remote storage. Feel free to leave this value to the default, or read more about choosing file sizes.
The other option on this page is about how far back you want to store old backups, sometimes called “retention”. Backups older than the specified range will be deleted after a backup has completed. Deleting old backups can free up space on the remote destination.
Please note: Duplicati will not free storage space immediately when you change the setting. This is because old backup data might be stored in the same file as current backup data. When the backup runs the next time, Duplicati will check if current backup data can be rearranged so that files can be deleted without uploading too much current data again.
The “Advanced options” area lets you tinker with all the different special options that Duplicati supports. You should only use these options if you really know what you are doing.
Finally, you can click the “Save” button to store the backup configuration. If you have automatically generated a passphrase, you are now promted to write it down and keep it safe. If you lose the passphrase, you cannot recover the backup, and there is no way to recover your data.
7. Running the backup
Now that the backup is configured, you can let it be, and it will run at the scheduled time. If you are impatient, you can click the “Run now” link and have the backup run immediately.
Questions
If you have questions, try asking on this forum
