I ran a full verification test on one of my main data stores because I am trying to make sure I don’t have any data rot in my backups. The results of the test show that there were a few errors that I I don’t understand. Below is the log of the test.
MainOperation: Test
Verifications: [
Key: duplicati-20190329T051005Z.dlist.zip.aes
Value: [],
Key: duplicati-20190212T051414Z.dlist.zip.aes
Value: [],
Key: duplicati-20190316T051217Z.dlist.zip.aes
Value: [],
Key: duplicati-20190106T035227Z.dlist.zip.aes
Value: [],
Key: duplicati-20190331T234946Z.dlist.zip.aes
Value: [],
ParsedResult: Error
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 04/02/2019 23:44:53 (1554248693)
BeginTime: 04/01/2019 17:35:30 (1554140130)
Duration: 1.06:09:23.9335940
Messages: [
2019-04-01 17:35:30 +00 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Test has started,
2019-04-01 17:35:30 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-04-01 17:35:37 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (27.64 KB),
2019-04-01 17:35:38 +00 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-IgnoreRemoteDeletedFile]: ignoring remote file listed as Deleted: duplicati-20190107T103457Z.dlist.zip.aes,
2019-04-01 17:35:38 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20190329T051005Z.dlist.zip.aes (104.92 KB),
Warnings: []
Errors: [
2019-04-01 19:37:44 +00 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-ba4569df9b37a4c01865506d9f7319503.dblock.zip.aes,
2019-04-01 19:38:24 +00 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-bd0a2b8430d444fd49a04511b12aea54a.dblock.zip.aes,
2019-04-01 22:50:08 +00 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b682234a12bdc45fa99a9092dd9040054.dblock.zip.aes,
2019-04-01 22:51:16 +00 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-bb1d4e41e5f4c4d6b8709febb4a897d13.dblock.zip.aes,
2019-04-01 22:52:56 +00 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-be84140604fee46c886d376a998589994.dblock.zip.aes,
BackendStatistics:
RemoteCalls: 29839
BytesUploaded: 0
BytesDownloaded: 1433960065698
FilesUploaded: 0
FilesDownloaded: 28186
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 1537
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 28302
KnownFileSize: 1445755619958
LastBackupDate: 03/31/2019 23:49:46 (1554076186)
BackupListCount: 9
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
I’ve had two backups run since this test without error. Should I be concerned by these results? If so, do I need to do something? Or does Duplicati automatically correct any errors it finds when running a test.
Hey @fognar, good job considering testing your backups!
As of now Duplicati doesn’t automatically fix errors it finds while testing. My GUESS is that the errors about not testing some dblock files (where data blocks are stored) are related to the earlier message about ignoring a “deleted” dlist file.
I’d suggest running a compact (to clear out the “deleted” dlist file) and that may make the dblock errors go away.
If so, let us know as that’s a reporting but we can fix.
The web log only shows the first 5 or so messages in a block (hence the “…” before the closing bracket for the Warnings and Errors) so it’s possible the same files are erroring but in a different order.
For a complete log you could use the --log-file parameter - though that can get pretty big unless you also play with --log-file-log-level and --log-file-log-filter.
In paying closer attention to your provided log I see the BackendStatistics reports 894 retry attempts for the 29,838 downloaded files. That’s almost a 3% retry (failure?) rate - it’s possible (likely?) that the “failed to process file” errors are related to those files.
Can you check how many files are actually in the destination? If it’s around 29,838 then my guess is that you’re running into connectivity issue making some of the downloads fail (and thus not get tested).
I was going to say that connectivity issues are unlikely since I currently have the backup box hooked directly to the same router as my main server, but then I remembered that I still have it going through the same SSH tunnel that I have setup when it’s away. Then on top of that my ssh connection that I opened to check the file count died on me after only a few seconds 3 times in a row.
So I guess I need to sort out some SSH tunnel issues before I can do a proper check. That or change the destination to reflect that it’s here in the house right now.
The remote did have a few more files than whats listed here but it also is 6 days older so I guess that is probably to be expected.
