I have configured duplicati with FTPS connection. I have added self-signed cert to trusted. FTP server is working on QNAP.
After one of updates of QNAP it started throwing error in duplicati:
Failed: One or more errors occurred. (The remote server returned an error: 150 Opening BINARY mode data connection
Duplicati is running in Docker on linux machine.
Duplicati version: 2.0.6.3_beta_2021-06-17
QNAP version: 5.0.0.1808
I tried also with passive mode, same result. I tried also checking files and DB repair.
Full log:
Failed: One or more errors occurred. (The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
.) (One or more errors occurred. (The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
Details: System.AggregateException: One or more errors occurred. (The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
.))) ---> System.AggregateException: The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
.)) ---> System.Net.WebException: The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream.
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x00115] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.AsyncProtocolRequest.StartOperation (System.Threading.CancellationToken cancellationToken) [0x0008b] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Threading.Tasks.TaskToApm.End (System.IAsyncResult asyncResult) [0x0002a] in <d13c8b563008422a8c5aaec0a74089cc>:0
at System.Net.Security.SslStream.EndAuthenticateAsClient (System.IAsyncResult asyncResult) [0x00000] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.TlsStream.EndAuthenticateAsClient (System.IAsyncResult asyncResult) [0x00000] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at (wrapper remoting-invoke-with-check) System.Net.TlsStream.EndAuthenticateAsClient(System.IAsyncResult)
at System.Net.FtpControlStream.SSLHandshakeCallback (System.IAsyncResult asyncResult) [0x0000c] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <2a3ee711c7c04f6c957360f2cf183a7f>:0
at Duplicati.Library.Utility.AsyncHttpRequest.GetRequestStream (System.Int64 contentlength) [0x00068] in <2a3ee711c7c04f6c957360f2cf183a7f>:0
at Duplicati.Library.Backend.FTP.PutAsync (System.String remotename, System.IO.Stream input, System.Threading.CancellationToken cancelToken) [0x0029d] in <5d38af7d86584ba0b36bdbc1a6e4b2c4>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Interface.IBackend backend, System.Threading.CancellationToken cancelToken) [0x00426] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.<UploadFileAsync>b__0 () [0x0010a] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func`1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x0017c] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func`1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x003a5] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadFileAsync (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x000da] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadBlockAndIndexAsync (Duplicati.Library.Main.Operation.Backup.VolumeUploadRequest upload, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00098] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func`2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d4] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel`1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x001da] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0011c] in <e60bc008dd1b454d861cfacbdd3760b9>:0
---> (Inner Exception #0) System.AggregateException: The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <e60bc008dd1b454d861cfacbdd3760b9>:0 <---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. (The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
.) ---> System.Net.WebException: The remote server returned an error: 150 Opening BINARY mode data connection for Backup/samba/duplicati-bef84e78c3c8a4480a6ae8194b3f1a7ab.dblock.zip.aes
Log data:
2021-10-20 06:24:43 +00 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
