Getting this strange error. When I edit my Backup Config, under Destination, there is a “Test Connection” button. When I click this button the test fails with “FTP Error 425, Can't open Data connection”. When I point it to another folder on the FTP Server (same login) with fewer files (say < 1000), the test is successful.
The destination folder is the original folder on the FTP server that Duplicati backup to for just over a year, so the file count is 1500+. I’ve tried a few folders and noticed that any folder with more than 1000 files fails this “Test” action.
I’ve also tried the same folder on the FileZilla client, and it can open the folder. The FileZilla Server does show me that the connection was aborted by Duplicati (“425 Error while transfering data: ECONNABORTED - Connection aborted”).
Why would a high file count in the destination folders cause this error? It also causes problems with the backup, that are successful, but it still errors at the last minute.
Duplicati - 2.0.6.3_beta_2021-06-17
Running on Windows Server 2016, Using FileZilla Server as the destination (FileZilla Server 1.4.1)
The Duplicati logs shows the following:
Feb 14, 2023 5:14 PM: Request for http://localhost:8200/api/v1/remoteoperation/test gave error
System.Net.WebException: The remote server returned an error: (425) Can't open data connection.
at System.Net.FtpWebRequest.DataStreamClosed(CloseExState closeState)
at System.Net.FtpDataStream.System.Net.ICloseEx.CloseEx(CloseExState closeState)
at System.Net.FtpDataStream.Dispose(Boolean disposing)
at System.IO.Stream.Close()
at Duplicati.Library.Utility.OverrideableStream.Dispose(Boolean disposing)
at System.IO.StreamReader.Dispose(Boolean disposing)
at System.IO.TextReader.Dispose()
at Duplicati.Library.Backend.FTP.<List>d__18.<>m__Finally1()
at Duplicati.Library.Backend.FTP.<List>d__18.System.IDisposable.Dispose()
at Duplicati.Library.Interface.BackendExtensions.TestList(IBackend backend)
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection(String url, RequestInfo info)
at Duplicati.Server.WebServer.RESTHandler.DoProcess(RequestInfo info, String method, String module, String key)
Feb 14, 2023 5:14 PM: Reporting error gave error
System.ObjectDisposedException: Cannot write to a closed TextWriter.
at System.IO.__Error.WriterClosed()
at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder)
Then the backup log is as follows:
System.AggregateException: One or more errors occurred. ---> System.AggregateException: The remote server returned an error: (425) Can't open data connection. ---> System.Net.WebException: The remote server returned an error: (425) Can't open data connection.
at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext()
---> (Inner Exception #0) System.AggregateException: The remote server returned an error: (425) Can't open data connection. ---> System.Net.WebException: The remote server returned an error: (425) Can't open data connection.
---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (425) Can't open data connection.
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (425) Can't open data connection.
Edit: Ok I’ve now tested a bit with the file count, it starts failing exactly at 600 files, so 601 files fail, and 600 files does not fail.
Edit 2: I’ve now used the “FTP (Alternative)” and this one does not have this problem. I was using the “FTP” option.
