Hey there,
first of all, I’m using Duplicati for a half year now and I’m still impressed. This is so great work you all did here!
But now I have a problem, I couldn’t find a solution for. Neither on Google, nor here on the forums.
I wanted to establish a ftp-connection to my FRITZ!Box. Duplicati 2.0.2.13_canary_2017-11-22 is running on Debian 9 (stretch) without graphical interface, both fully updated.
First I began with just typing in the web-interface my IP, Path, username and password. Then I tested it and it responded with Failed to connect: Server returned an error: 530 Must use AUTH TLS.
So I turned on SSL Test. Failed to connect: The authentication or decryption has failed.
After I got this, I marked the option accept-specified-ssl-hash and entered my hash I got. All right? No!
Test - Failed to connect: Server returned an error: 425 Can’t open passive connection
I don’t know why, because in Filezilla on my other computer it’s running perfectly. I’ve also tried ftp in Debian, it’s also working.
Then if I try to force ftp-passive, it of course, tells me the same error. But if I try ftp-regular, it says Failed to connect: Couldn’t open listening socket on client.
And here’s, where I got stuck and don’t know how to get this fixed. Also I tried to accept-any-ssl-certificate and get the same error…
If anyone got a hint for me, I’d appreciate it so much!
Thank you for reading and have a great day!
Edit: Now I tried it on my Windows desktop and here it’s working with all the same parameters.
I also saw if I do on my Debian pc a service duplicati status request, I get:
duplicati.service - Duplicati web-server
Loaded: loaded (/lib/systemd/system/duplicati.service; disabled; vendor preset: enabled)
Active: inactive (dead)
The funny thing is, the webinterface is running and working.
If I start it, it says ● duplicati.service - Duplicati web-server
Active: active (running) since Fri 2017-12-08 15:23:36 CET; 1s ago
Main PID: 1766 (Main)
Tasks: 11 (limit: 4915)
CGroup: /system.slice/duplicati.service
├─1766 DuplicatiServer /usr/lib/duplicati/Duplicati.Server.exe
└─1770 /usr/bin/mono-sgen /usr/lib/duplicati/Duplicati.Server.exe
A bunch a seconds after it, I did nothing, just wait, it turns into:
Active: failed (Result: exit-code) since Fri 2017-12-08 15:24:07 CET; 15s ago
Process: 1975 ExecStart=/usr/bin/duplicati-server $DAEMON_OPTS (code=exited, status=200/CHDIR)
Main PID: 1975 (code=exited, status=200/CHDIR)Dez 08 15:24:07 Server systemd[1]: duplicati.service: Unit entered failed state.
Dez 08 15:24:07 Server systemd[1]: duplicati.service: Failed with result ‘exit-code’.
Dez 08 15:24:07 Server systemd[1]: duplicati.service: Service hold-off time over, scheduling restart.
Dez 08 15:24:07 Server systemd[1]: Stopped Duplicati web-server.
Dez 08 15:24:07 Server systemd[1]: duplicati.service: Start request repeated too quickly.
Dez 08 15:24:07 Server systemd[1]: Failed to start Duplicati web-server.
I don’t know if it has something to do with it, because before I tried FTP I didn’t have problems with Duplicati.
The only thing I changed, was installing ftp and ftp-ssl to try the connection just without Duplicati.
