FreeBSD Availability?
I’ve been stuck on 2.0.7.103_canary_2024-04-19 for a long time now as it appears any builds suitable for FreeBSD are no longer created. Even then I had to pin an old version of SQLite to allow it to continue working.
I’ve had to update SQLite now so Duplicati no longer works for me. Is there any way of getting newer versions of Duplicati to work on FreeBSD or is it a lost cause now?
The issue is that the official .NET runtime does not support FreeBSD targets, so we cannot currently build those. The FreeBSD port of .NET is not seeing a lot of action: FreshPorts -- lang/dotnet: Open-source developer platform and a cross-platform runtime for cloud, mobile, desktop, and IoT apps
So yes, getting a native package is currently not feasible.
You can try something like Podman, Linuxulator, or bhyve to run the Linux-based builds.
