I set up a test linux VM running Fedora 36 and Duplicati, backing up to OneDrive. I started with a small backup job, just my /home directory on the VM. The backup appears to have partially worked, but it threw three errors:
* 2022-11-02 15:34:22 -07 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20221102T223333Z.dlist.zip.aes
* 2022-11-02 15:35:06 -07 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i3eef55e3dc994ac5b9908f53b879bb54.dindex.zip.aes
* 2022-11-02 15:35:51 -07 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b8519fcbef0b94fa2b5f0e9498f7c9c34.dblock.zip.aes
Those three files are also present if I view my OneDrive directly, so Duplicati was successfully able to connect and write at least some data.
I didn’t see anything recent in the archives when searching these errors. Help is appreciated.
That’s an umbrella Microsoft marketing term. What Storage Type did you set on Duplicati Destination?
Is that from a job log summary? If so, look for same files in Complete log view, maybe in “TestResults”.
Error details are required. They would be there, but unfortunately not on the one-line summary of errors.
OK - thanks for the pointer to the more detailed error logs. That error code (“cannot send a content-body with this verb-type”) allowed me to find more search results in the forum.
I moved to using OneDrive v2 and that successfully backed up for me.
