Two other (small) backup jobs completed the DB conversion involved with the upgrade, this larger one backing up the system though has not. Profiling indicated that the SQL query is taking ~7 hours to complete:
Jun 13, 2023 10:23 AM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 335 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 335 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” ))
Jun 13, 2023 10:23 AM: ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 296 took 0:00:00:00.052
Jun 13, 2023 10:23 AM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 296
Jun 13, 2023 10:23 AM: ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 296 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 296 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” )) took 0:07:19:54.075
Jun 13, 2023 3:03 AM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 296 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 296 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” ))
Jun 13, 2023 3:03 AM: ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 265 took 0:00:00:00.041
Jun 13, 2023 3:03 AM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 265
Jun 13, 2023 3:03 AM: ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 265 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 265 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” )) took 0:06:59:27.341
Jun 12, 2023 8:04 PM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 265 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 265 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” ))
Jun 12, 2023 8:04 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 233 took 0:00:00:00.059
Jun 12, 2023 8:04 PM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM “FilesetEntry” WHERE “FilesetEntry”.“FilesetID” = 233
Jun 12, 2023 8:04 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM (SELECT DISTINCT “Path” FROM ( SELECT “L”.“Path”, “L”.“Lastmodified”, “L”.“Filelength”, “L”.“Filehash”, “L”.“Metahash”, “L”.“Metalength”, “L”.“BlocklistHash”, “L”.“FirstBlockHash”, “L”.“FirstBlockSize”, “L”.“FirstMetaBlockHash”, “L”.“FirstMetaBlockSize”, “M”.“Hash” AS “MetaBlocklistHash” FROM ( SELECT “J”.“Path”, “J”.“Lastmodified”, “J”.“Filelength”, “J”.“Filehash”, “J”.“Metahash”, “J”.“Metalength”, “K”.“Hash” AS “BlocklistHash”, “J”.“FirstBlockHash”, “J”.“FirstBlockSize”, “J”.“FirstMetaBlockHash”, “J”.“FirstMetaBlockSize”, “J”.“MetablocksetID” FROM ( SELECT “A”.“Path” AS “Path”, “D”.“Lastmodified” AS “Lastmodified”, “B”.“Length” AS “Filelength”, “B”.“FullHash” AS “Filehash”, “E”.“FullHash” AS “Metahash”, “E”.“Length” AS “Metalength”, “A”.“BlocksetID” AS “BlocksetID”, “F”.“Hash” AS “FirstBlockHash”, “F”.“Size” AS “FirstBlockSize”, “H”.“Hash” AS “FirstMetaBlockHash”, “H”.“Size” AS “FirstMetaBlockSize”, “C”.“BlocksetID” AS “MetablocksetID” FROM “File” A LEFT JOIN “Blockset” B ON “A”.“BlocksetID” = “B”.“ID” LEFT JOIN “Metadataset” C ON “A”.“MetadataID” = “C”.“ID” LEFT JOIN “FilesetEntry” D ON “A”.“ID” = “D”.“FileID” LEFT JOIN “Blockset” E ON “E”.“ID” = “C”.“BlocksetID” LEFT JOIN “BlocksetEntry” G ON “B”.“ID” = “G”.“BlocksetID” LEFT JOIN “Block” F ON “G”.“BlockID” = “F”.“ID” LEFT JOIN “BlocksetEntry” I ON “E”.“ID” = “I”.“BlocksetID” LEFT JOIN “Block” H ON “I”.“BlockID” = “H”.“ID” WHERE “A”.“BlocksetId” >= 0 AND “D”.“FilesetID” = 233 AND (“I”.“Index” = 0 OR “I”.“Index” IS NULL) AND (“G”.“Index” = 0 OR “G”.“Index” IS NULL) ) J LEFT OUTER JOIN “BlocklistHash” K ON “K”.“BlocksetID” = “J”.“BlocksetID” ORDER BY “J”.“Path”, “K”.“Index” ) L LEFT OUTER JOIN “BlocklistHash” M ON “M”.“BlocksetID” = “L”.“MetablocksetID” ) UNION SELECT DISTINCT “Path” FROM ( SELECT “G”.“BlocksetID”, “G”.“ID”, “G”.“Path”, “G”.“Length”, “G”.“FullHash”, “G”.“Lastmodified”, “G”.“FirstMetaBlockHash”, “H”.“Hash” AS “MetablocklistHash” FROM ( SELECT “B”.“BlocksetID”, “B”.“ID”, “B”.“Path”, “D”.“Length”, “D”.“FullHash”, “A”.“Lastmodified”, “F”.“Hash” AS “FirstMetaBlockHash”, “C”.“BlocksetID” AS “MetaBlocksetID” FROM “FilesetEntry” A, “File” B, “Metadataset” C, “Blockset” D, “BlocksetEntry” E, “Block” F WHERE “A”.“FileID” = “B”.“ID” AND “B”.“MetadataID” = “C”.“ID” AND “C”.“BlocksetID” = “D”.“ID” AND “E”.“BlocksetID” = “C”.“BlocksetID” AND “E”.“BlockID” = “F”.“ID” AND “E”.“Index” = 0 AND (“B”.“BlocksetID” = -100 OR “B”.“BlocksetID” = -200) AND “A”.“FilesetID” = 233 ) G LEFT OUTER JOIN “BlocklistHash” H ON “H”.“BlocksetID” = “G”.“MetaBlocksetID” ORDER BY “G”.“Path”, “H”.“Index” )) took 0:07:02:49.088
