Files incorrectly flagged as modified
Hello everyone!
New user of duplicati, and very impressed so far. I’ve encountered a problem that could use your help, searching the forums has not led to an answer. One of my backup jobs is repeatedly backing up files that I have not touched in months. I turned on verbose logging, and the files are logged similar to the below:
2024-01-31 18:28:13 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes U:\Movies\Finding Dory (2016).mkv, new: False, timestamp changed: False, size changed: False, metadatachanged: True, 1/1/2021 6:22:24 PM vs 1/1/2021 6:22:24 PM
2024-01-31 18:32:48 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileMetadataChanged]: File has only metadata changes U:\Movies\Finding Dory (2016).mkv
After this, the file is one of the “48265 modified entries:” listed under output of the compare commandline function.
Looks like duplicati is detecting a metadata change, even though I am certain that this file (and hundreds of similar files) have not been touched in ages, neither have their parent directories. I suspect this may have something to do with the fact that the files live on a ubuntu server that is mapped to my windows 11 computer as a shared drive (U:). Duplicati runs on the windows computer.
Perhaps using --disable-filetime-check will resolve the issue, but I think it will significantly prolong backup times. Are there any other potential solutions?
Thanks!
Due to deduplication, it’s hard to tell when a file is backed up, as opposed to just read through to see what changed. Only if something changed is an upload done on behalf of that file. What do you see?
One can guess based on upload size, which is in Complete log, but there are better (harder) ways.
Simple way for you would be to find a large file that shows the behavior, and create a new backup to isolate the statistics to that one file. While looking for files, look for a small one too. Might test it later.
What does Windows File Explorer show when you right-click the file and check Properties carefully? Hopefully that will reveal some change, but if not, you can backup the small file to unencrypted local folder, so we can try taking things apart to see if something else in the metadata somehow changed.
This is not unlikely. File sharing via Samba is tricky. I am doing this very operation with a NAS that is also a Linux computer and I don’t see that. Maybe there is something special in your Samba setup ? Like @ts678 said, examining the files before a backup and the following using Windows explorer could help but there could be finer changes that are not displayed even in the explorer - Duplicati code use ticks (100 nanoseconds) and any variance in calculation could trigger an update.
Possibly you could indeed restrict the test to a backup with ONE file and see if there is indeed a new upload with each backup. In this case, you could get at the 2 last dblock files uploaded using any tool specific to your backend or using Duplicati.BackendTool.exe, unencrypt the 2 files (that should be very small as they will hold only the changed metadata for the file, so about 600 bytes) with SharpAESCrypt.exe (start it without any parameter for syntax). then unzip the result like this, there should be only ONE data block in each unzipped dblock file (besides the manifest that is useless for you):
unzip duplicati-b2ba655a47fc9428e9adaff69f6a7e26c.dblock.zip
Archive:  duplicati-b2ba655a47fc9428e9adaff69f6a7e26c.dblock.zip
  inflating: manifest
  inflating: SwYyI6aaadfRYG3Z1nlyNcCSyjkeBQtM1XWg4xIdBcU=
cat SwYyI6aaadfRYG3Z1nlyNcCSyjkeBQtM1XWg4xIdBcU\=
{"unix:uid-gid-perm":"1001-1001-436","unix:owner-name":"gp","unix:group-name":"gp","CoreAttributes":"Normal","CoreLastWritetime":"638424196270405969","CoreCreatetime":"638424196270405969"}
and same thing for previous block:
cat hqUar6bwj4wlEjVFbO4QmMUAxRTb56ofpx9QDKmQupg\=
{"unix:uid-gid-perm":"1001-1001-436","unix:owner-name":"gp","unix:group-name":"gp","CoreAttributes":"Normal","CoreLastWritetime":"638424217175289574","CoreCreatetime":"638424217175289574"}
the huge values in times are ticks (100 ns). Either the difference will come from ticks, or of attributes.
I was hoping it wouldn’t come to that, but it might. A simplification is do an unencrypted backup to a local folder. The data and the metadata are mixed together in the dblock, but a super-short file may be shorter than its metadata. A longer file will have a short block at the end. You might also pick up folder metadata.
if one does a ‘touch’ on the Linux file, only the metadata has changed, that’s how I did the test. In this case the dblock files has only one block, the metadata.
is still open. Did you just disprove it? I thought there was some code that needed a file content change before it would make a new version. There are also time-resolution issues there that might apply here.
I’m not sure at all. The issue thread is very long and it’s late now for me to read it all. I’m wondering why no one suggested to make a change to the manifest file to reflect the change in the backend format ? it could help to solve the backward compatibility problem (well, possibly. That’s just a quick thought)
Thank you everyone for the detailed advice. I’m going to try to answer all the (very helpful) follow up questions here:
  1. The file I highlighted U:\Movies\Finding Dory (2016).mkv is a 8.09GB file, and it continues to be backed up daily. For example, here are the entries from the last night’s backup, which duplicates the results on 2024-01-31:
2024-02-01 02:40:29 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes U:\Movies\Finding Dory (2016).mkv, new: False, timestamp changed: False, size changed: False, metadatachanged: True, 1/1/2021 6:22:24 PM vs 1/1/2021 6:22:24 PM
2024-02-01 02:45:25 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileMetadataChanged]: File has only metadata changes U:\Movies\Finding Dory (2016).mkv
  1. Upon running the compare commandline function with --full-result, the same file is listed as one of the 40897 modified entries. So I am pretty sure it’s being backed up repeatedly
  2. Windows explorer properties shows the created and modified dates as 2021-01-01 13:22:24, Accessed 2024-02-01 (likely during backup). Nothing seems to indicate any recent modification of file.
  3. I don’t think there is anything special about my samba setup, but I have not reconfigured it in years.
  4. The file is being backed up to a local store (on the same windows machine that is running duplicati), no encyption. I will create a new backup task for just that file and post the results here.
  5. Thank you for sharing the github issue. I will try to parse through it and see if I learn anything, post here.
I just finished reviewing that GitHub issue. Seems like it refers to Duplicati falsely detecting a timestamp change, forcing a re-read/re-hash of the file, then finding that the hash matches and not backing up the file. In the issue posted here, duplicati is detecting timestamp changed: False, and metadatachanged: True, then backing up the file - perhaps the opposite of the GitHub thread.
If you were up to that (phew), perhaps an easy approach to deciding what changed is to look in the DB with DB Browser for SQLite or similar, preferably on a copy of the database to remove chance of harm.
is from me using attrib +r and attrib -r to see what happens. That’s a more pure test than touch (which on Windows I tried just by having notepad save the file again), as touch changes the timestamp.
Here’s how the metadata block looked while that file had the readonly attribute:
{"win-ext:accessrules":"[]","CoreAttributes":"ReadOnly, Archive","CoreLastWritetime":"638424781684946339","CoreCreatetime":"637519769445889153"}
Got anything small that does this? I wouldn’t want to dig for the metadata block in anything that big, but one way to get a clue on whether data actually changed is to follow the image example above, with the Filter box helping you search. If BlocksetID stayed the same, no additional file data was backed up. MetadataID is probably changing, but we don’t know how until you find some, preferably on a short file.
I also ran this experiment to see how job log and the compare show metadata-only change. It is shown.
Getting a little further aside from the above (maybe), are your daily backups making new file versions?
The below is the issue I was aiming at, but it might not even be filed as an issue yet. Was it in the one reviewed? It’s probably at least a bit related, because it has to do with the timestamp resolutions used.
is after a database Recreate, which pulls in the seconds-resolution timestamps from the dlist file, and here they’re 100 nanoseconds, which adds 7 trailing zeros that weren’t there before, and won’t be on next backup, which will declare a timestamp mismatch, show timestamps to the second, and not fix it (assuming nothing else triggers a new backup version).
Checking file for changes C:\backup source\short.txt, new: False, timestamp changed: True, size changed: False, metadatachanged: False, 2/2/2024 1:42:48 PM vs 2/2/2024 1:42:48 PM
One difference in the result is that the job log shows the file as opened (and it’s read) but not modified. Clearing up this read-through after recreate happens (I think) if source gets actual change, likely soon.
So I created a new, separate backup task just for the same file. The first backup run ran as expected, and on the second backup run, metadatachanged: True was detected, the file was flagged as “modified,” but apparently not backed up? Here are the (selected) logs:
2024-02-02 08:00:00 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes U:\Movies\Finding Dory (2016).mkv, new: False, timestamp changed: False, size changed: False, metadatachanged: True, 1/1/2021 6:22:24 PM vs 1/1/2021 6:22:24 PM
2024-02-02 08:02:33 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileMetadataChanged]: File has only metadata changes U:\Movies\Finding Dory (2016).mkv
2
…and the backup summary:
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 1
ExaminedFiles: 1
OpenedFiles: 1
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 8688916038
SizeOfOpenedFiles: 8688916038
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
ParsedResult: Success
Version: 2.0.7.1 (2.0.7.1_beta_2023-05-25)
EndTime: 2/2/2024 8:02:41 AM (1706878961)
BeginTime: 2/2/2024 8:00:00 AM (1706878800)
Duration: 00:02:41.7238272
MessagesActualLength: 19
WarningsActualLength: 0
ErrorsActualLength: 0
LimitedMessages: [
    2024-02-02 08:00:00 -05 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
    2024-02-02 08:00:00 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:  (),
    2024-02-02 08:00:00 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed:  (19 bytes),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b52138b761d57426fb24f37660c5c29e6.dblock.zip (640 bytes),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b52138b761d57426fb24f37660c5c29e6.dblock.zip (640 bytes),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i602015c6381440ed942ea220ec9f4154.dindex.zip (563 bytes),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i602015c6381440ed942ea220ec9f4154.dindex.zip (563 bytes),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20240202T130000Z.dlist.zip (1.57 KB),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20240202T130000Z.dlist.zip (1.57 KB),
    2024-02-02 08:02:34 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteResults]: No remote filesets were deleted,
LimitedWarnings: []
LimitedErrors: []
Output of the compare command is:
Listing changes
  1: 2/1/2024 9:25:40 PM
  0: 2/2/2024 8:00:00 AM
Size of backup 1: 8.09 GB
  1 modified entries:
  ~ U:\Movies\Finding Dory (2016).mkv
  Modified files:    1
Size of backup 0: 8.09 GB
Return code: 0
So if duplicati appears to be processing the file correctly in the end - even though it flags a metadata change, it’s not actually backing up the file. This confirms the example of @ts678 above (though some of the text appears cut off, I think I get the gist). This leads me back to my original problem, where every night duplicati is backing up a lot of data for a drive that should be more or less static. What is the best way to find out precisely which files are being re-backed up every night?
this is the file you need to unzip, it should hold a file called ‘manifest’ and another with a long coded name, inside this file there is the metadata that triggered the backup. Save this metadata somewhere and trigger again your test backup until it is saving a new backup set. Repeat the operation for the new dblock file and compare the 2 metadata.
Here we go - old metadata:
{"win-ext:accessrules":"[{\"Rights\":1179785,\"ControlType\":0,\"SID\":\"S-1-1-0\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0},{\"Rights\":1180063,\"ControlType\":0,\"SID\":\"S-1-5-21-3567941941-338316017-65753321-1000\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0},{\"Rights\":1966591,\"ControlType\":0,\"SID\":\"S-1-22-2-1000\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0}]","win-ext:accessrulesprotected":"True","CoreAttributes":"Archive","CoreLastWritetime":"637451221445148041","CoreCreatetime":"637451221445148041"}
New metadata:
{"win-ext:accessrules":"[{\"Rights\":1179785,\"ControlType\":0,\"SID\":\"S-1-1-0\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0},{\"Rights\":1180063,\"ControlType\":0,\"SID\":\"S-1-5-21-3567941941-338316017-65753321-1000\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0},{\"Rights\":1966591,\"ControlType\":0,\"SID\":\"S-1-22-2-1000\",\"Inherited\":false,\"Inheritance\":0,\"Propagation\":0}]","win-ext:accessrulesprotected":"True","CoreAttributes":"Archive","CoreLastWritetime":"637451221445148041","CoreCreatetime":"637451221440741761"}
The only difference is CoreCreatetime changed from 637451221445148041 to 637451221440741761. The file has not been accessed in any way other than the backup task. Does this help?
(in my previous, deleted post, I had outlined how I was unable to reproduce the error, but I tried again and the error is back. Hence this post)
converted using https://www.datetimetoticks-converter.com/ both represent 01/01/2021 18:22:24
the difference is about 4 seconds.
This may be Samba related, there is this thread for example that shows similar troubles with file dates and Samba.
Thanks and yes, the difference is 440 milliseconds. Interesting that Duplicati is flagging this as a metadatachange and not timestampchange.
I’m going to try to force my linux NAS and windows PC to all sync from the same NTP timeserver to see if that helps. Which brings us to the GitHub issue referenced by @ts678 - perhaps limiting timestamp comparisons to second-level resolution may be worth revisiting…
Maybe the timestamp refers only to the modification date ? as I understand it, the metadata is a blob read from the OS, that can hold data that Duplicati does not understand (or even try to). As it may be of interest to the file users, it needs to be preserved, and can be restored (if the operating system match at least).
It seems very unlikely, since the date is written to disk it should not depend on the current date.
As I said creation date is part of the metadata that Duplicati does not touch or even understand.
What you could consider is to look at the Samba version used on your server. Is it provided by the kernel ? if not, is it possible to update it to an up-to-date userspace version ? if yes, is it possible to try a newer kernel (or even if possible to switch to userspace Samba) ? Also, the thread I linked to is referring to the protocol level. Changing it is easier than updating Samba.
Also you could try to get at the file date in ticks directly without Duplicati using Powershell:
(get-itemproperty -path .\myfile.txt -name creationtime).creationtime.ticks
and on the Linux side, you can try stat. Not all filesystems support creation time. My ext4 does, so
$ stat /etc/issue
  File: /etc/issue
  Size: 32        	Blocks: 8          IO Block: 4096   regular file
Device: 803h/2051d	Inode: 1310901     Links: 1
Access: (0644/-rw-r--r--)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2024-01-25 11:43:35.740275219 -0500
Modify: 2023-06-06 05:52:26.000000000 -0400
Change: 2023-11-04 14:27:13.494531228 -0400
 Birth: 2023-11-04 14:27:13.494531228 -0400
One odd thing is that the difference in your time is not any nice even amount, and new one got older.
old GMT / UTC Date Time: 2021-01-01 18:22:24 + 0.5148041 second
new GMT / UTC Date Time: 2021-01-01 18:22:24 + 0.0741761 second
(from .NET DateTime Ticks Converter Online)
Possibly the least disruptive workaround for bogus metadata changes (whatever the cause) is option
  --check-filetime-only (Boolean): Checks only file lastmodified
    This flag instructs Duplicati to not look at metadata or filesize when
    deciding to scan a file for changes. Use this option if you have a large
    number of files and notice that the scanning takes a long time with
    unmodified files.
    * default value: false
this should work. Obviously the fine details for metadata such as rights will be lost, but as the OP is doing a backup of a Linux computer using a Windows one, the correctness of these details would not be great anyway.
Great ideas. I am using the latest version of samba as provided by the kernel (Ubuntu 20.04.06 LTS, kernel 5.4.0-170-generic, Samba version 4.15.13-Ubuntu using protocol/dialect 3.1.1). At present, I’m not ready to move this to the userspace samba (latest version appears to be 4.19.4).
I’m suggesting (as I think the GitHub thread was, as well) that perhaps Duplicati can modify the way it chooses to flag a file as “different” - move from a 100 nanosecond to a 1 second resolution. I recognize that this may be a big change and will leave it to the smarter people to consider.
Here’s the output for the file in question - it appears to exactly match the “old” metadata read. Is it suspicious that the fractional part of the “Change” timestamp (and not the rest of it) is exactly the same as the fractional part of the “new” timestamp?
  File: Finding Dory (2016).mkv
  Size: 8688916038      Blocks: 16970552   IO Block: 4096   regular file
Device: fd00h/64768d    Inode: 39845897    Links: 1
Access: (2674/-rw-rwsr--)  Uid: ( 1000/      mw)   Gid: ( 1000/      mw)
Access: 2024-02-04 05:13:04.431934651 -0500
Modify: 2021-01-01 13:22:24.514804109 -0500
Change: 2024-02-04 04:50:03.074176120 -0500
 Birth: -
Output (from windows machine, looking to samba share): 637451041440741761
