Hello together,
I just started using duplicati and have a small problem. After creating a new backup configuration I started backing up manually. When I want to backup the same folder again I get the message “Found 3 files that are missing from the remote storage, please run repair”. I checked it and all files are existing. When I try to repair the Backup database I get the following message:
“The backup storage destination is missing data files. You can either enable --rebuild-missing-dblock-files or run the purge command to remove these files. The following files are missing: duplicati-ba134736523f948a190a7dd6d971ebedf.dblock.zip.aes”
But this file is also existing.
I stored the Backup via WebDav (Nextcloud).
Any Idea what is the problem ehre and how to fix?
