I have 2 different backups on the same system failing in apparently the same manor.
Here is the first stack trace:
Result
failed
Errors
Duplicati Backup report for zz.s.backups
Failed: One or more errors occurred.
Details: System.AggregateException: One or more errors occurred. —> System.AggregateException: Could not find file ‘C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266’. —> System.IO.FileNotFoundException: Could not find file ‘C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<b__0>d.MoveNext()
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task) at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result) at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action1 method)
—> (Inner Exception #0) System.AggregateException: Could not find file ‘C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266’. —> System.IO.FileNotFoundException: Could not find file ‘C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266’.
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() ---> (Inner Exception #0) System.IO.FileNotFoundException: Could not find file 'C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266'. File name: 'C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__101.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__13.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()<—
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. —> System.Net.WebException: The remote server returned an error: (507) Insufficient Storage.
at Duplicati.Library.Utility.AsyncHttpRequest.AsyncWrapper.GetResponseOrStream()
at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse()
at Duplicati.Library.Backend.WEBDAV.d__36.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.d__21.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.d__18.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.d__17.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.d__15.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<b__13_0>d.MoveNext()
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of inner exception stack trace --- ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (507) Insufficient Storage. at Duplicati.Library.Utility.AsyncHttpRequest.AsyncWrapper.GetResponseOrStream() at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse() at Duplicati.Library.Backend.WEBDAV.<PutAsync>d__36.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__101.MoveNext()<—
Log data:
2020-06-24 19:45:10 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\Downloads\facemoods.exe.917.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\Downloads\facemoods.exe.917.gzquar’ is denied.
at Duplicati.Library.Common.IO.SystemIOWindows.<>c.b__29_0(String p)
at Duplicati.Library.Common.IO.SystemIOWindows.PathTooLongFuncWrapper[T](Func2 nativeIOFunc, Func2 alternativeIOFunc, String path, Boolean prefixWithUnc)
at Duplicati.Library.Common.IO.SystemIOWindows.FileOpenRead(String path)
at Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.<>c__DisplayClass1_0.<b__0>d.MoveNext()
2020-06-24 20:02:12 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2016.older\080216\Downloads\facemoods.exe.917.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2016.older\080216\Downloads\facemoods.exe.917.gzquar’ is denied.
2020-06-24 20:08:12 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2016.older\010116\monica’s.sync\123115\Downloads\facemoods.exe.917.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2016.older\010116\monica’s.sync\123115\Downloads\facemoods.exe.917.gzquar’ is denied.
2020-06-24 20:19:05 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2015.older\Downloads\Facemoods.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2015.older\Downloads\Facemoods.exe’ is denied.
2020-06-24 20:19:05 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2015.older\Downloads\facemoods.exe.118288.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2015.older\Downloads\facemoods.exe.118288.gzquar’ is denied.
2020-06-24 20:19:06 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2015.older\Downloads\facemoods.exe.917.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2015.older\Downloads\facemoods.exe.917.gzquar’ is denied.
2020-06-24 20:20:11 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2015.older\Downloads\YourFile_downloader.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2015.older\Downloads\YourFile_downloader.exe’ is denied.
2020-06-24 20:20:11 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\2015.older\Downloads{REQUEST}_downloader.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\2015.older\Downloads{REQUEST}_downloader.exe’ is denied.
2020-06-24 20:29:30 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\123115\Downloads\Facemoods.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\123115\Downloads\Facemoods.exe’ is denied.
2020-06-24 20:29:30 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\123115\Downloads\facemoods.exe.917.gzquar
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\123115\Downloads\facemoods.exe.917.gzquar’ is denied.
2020-06-24 20:30:27 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\123115\Downloads\YourFile_downloader.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\123115\Downloads\YourFile_downloader.exe’ is denied.
2020-06-24 20:30:28 -07 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: S:\S-drive\backups\Monica\123115\Downloads{REQUEST}_downloader.exe
System.UnauthorizedAccessException: Access to the path ‘S:\S-drive\backups\Monica\123115\Downloads{REQUEST}_downloader.exe’ is denied.
2020-06-25 01:48:53 -07 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
File name: ‘C:\Windows\TEMP\dup-c221087b-9693-4057-aecb-5940467ee266’
at CoCoL.AutomationExtensions.d__10`1.MoveNext()
Time of report
2020-06-25 01:49:12
Last change
2020-06-25 01:49:12
