File removal if removed from source
Hello, I had a search of the forum and could not find this topic.
If we have a source directory to backup to the cloud, and some of the files are removed, does Duplicati delete those files on the cloud storage solution?
thanks
Hello @steveeff and welcome to the forum!
Deleted files are kept as long as your retention setting says to when you create or edit the backup job. There’s no special support to find them though (at least from the GUI tree view – using find in Commandline can help). Each backup version is a snapshot of what’s there, so you’d have to go to an earlier version to do that restore.
Hello ts678, thanks for getting back to me! Just wondering, you mentioned “Deleted files are kept as long as your retention setting says to”. Do you know what kind of range I can opt to keep files or delete them for?
If you follow the create link I posted earlier (then scroll down) you can see that it’s entirely your choice, however there will obviously be more space taken if you keep things for a long time. The manual says:
The retention can be set in 3 ways:
Unlimited:
Backups will never be deleted. This is the most safe option, but remote storage capacity will keep increasing.
Until they are older than:
Backups older than a specified number of days, weeks, months or years will be deleted.
A specific number:
The specified number of backup versions will be kept, all older backups will be deleted.
however there are actually two other options now that let you progressively “thin out” the versions that are kept as time passes. One is a pre-set, and the other is a custom setting. New retention policy deletes old backups in a smart way. These are all on create/edit screen 5 under General Options with some help text.
There are no separate retention settings for old file versions and for totally deleted files. What you retain is what you retain. If you’re considering intentional deletion after backup (i.e. long-term archive), please don’t. Duplicati is fine for shorter-term deletion recovery, but it doesn’t have the UI or stability to keep only-copies.
