This isn’t exactly a support request (I managed to resolve the issue on my own), but it was rough enough of a transition that I figured it was worth saying something about it.
Saw the “manual update required” popup when running backups today. After they had completed I went to the download page and manually installed the .deb files
Access page immediately went “not logged in” and asked for a password that I had never set. I tried every password I could think of but none of them worked
Went back to the “home” page and it mentioned a TrayIcon app (which I don’t have)
Checked the logs and saw a login link to click on. It didn’t work (“Can’t log in”), logs showed “missing cookie” (which I’m thinking is a red herring)
Googled the issue, found this support site. Ended up editing /etc/default/duplicati to set a password, restarted the service, logged in, edited the same file to remove the password, restarted the service, confirmed I am still logged in.
Back up and running at about where I was before, but jeez that was a rough upgrade…
Same here: upgraded to 2.1.0.2 and suddenly I am prompted to login via password. I don’t know a password and there was no information during the upgrade.
Still figuring out what I can do. I am on Windows.
Well the only thing I can suggest right now is to try to launch Duplicati once with a commandline parameter of --webservice-password=<new password> to set a password
Same happened here as happened to OP. I have never had any sort of problem with Duplicati before.
I wasn’t too bothered by it…didn’t feel like finding a “fix” so I clobbered the whole thing, and started over from scratch with a fresh install. (it’s just me and my files over here!) Took less than 2 hours, starting from zero.
A better “how to upgrade, oh, and by the way…” doc would have been nice…the part about “use the TrayIcon to access your stuff now” should be front-and-center in a large red flashing headline.
This release had lots of changes. The release note describes:
IMO (and per feedback) the “slightly special” understates the impact of the new password need. Those using TrayIcon have a somewhat easier time but are probably puzzled by new breakage.
Added a help button to the connection dialog.
Added a help link to the login dialog.
Added a help link to the signin dialog.
just went in for next Canary (and eventually Beta and beyond), and may help the situation some.
Duplicati Access Password (various sections) is what the new help links look like they will link to.
Not quite so, but it’s the alternative if you have not yet set up a password, and have no desire to.
Where? People may miss the release notice (see quote above) and also the manual (see links).
Installer can’t do it. Download page can be bypassed by download link from a previous release.
I suppose one answer might be “everywhere possible”, but at least soon it’s nearby for upgrade.
As @ts678 we added a “Help” button and some more links to the next release.
For now, the idea is to go without silent updates. Later, I hope to add back some smooth auto-update support.
The non-admin updates generally worked, but there were lots of quirks. Especially for sysadmins who could not really see what versions were running by looking at the package managers.
They do if they start it. TrayIcon is duplicati and is often in /usr/bin. Maybe in app menu too.
Many Linux users might use the systemdServer version though. Windows is sort of reversed.
Installer only does TrayIcon. Getting a WindowsService server install takes more manual work.
It’s possible that Linux people don’t use the tray icon much, but I don’t know if statistics exist…
