Fedora 40, duplicati 2.1.0.103_canary_2024-12-21, selinux alerts
I just upgraded a Fedora 40 system to duplicati 2.1.0.103_canary_2024-12-21, and I’m getting a lot of selinux alerts. A test backup appears to be progressing nonetheless.
Did I miss an upgrade step? What can I do to quiet these alerts? The setroubleshooter steps don’t seem to be helping…
Follow-up…
Backup reported 68610 Warnings. The ones it shows (it doesn’t show all 68610) all appear to be of the form:
2025-01-04 20:33:40 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: FILE
FileLoadException: Unable to get symlink for “FILE”, error: EACCES (13)
Where “FILE” is a different file for each warning (but the same file within a single warning).
Discusses how new location of executables might impact SELinux, plus maybe a workaround.
Discussion might benefit from more SELinux expertise. If you have it, please post somewhere.
I tried this workaround from the linked thread Issues · duplicati/duplicati · GitHub
semanage fcontext -a -t bin_t '/usr/lib/duplicati/duplicati'
semanage fcontext -a -t bin_t '/usr/lib/duplicati/duplicati-*'
restorecon -r /usr/lib/duplicati/
So far, it doesn’t appear to have made any difference.
Digging through the thread and linked data I also see where another user updated SElinux policies - I will research those and see if they help in my case.
There is a problem with the “semanage” commands I quoted - the wildcard does not work. Here is a corrected version
for f in /usr/lib/duplicati/duplicati-*
do
  semanage fcontext -a -t bin_t ${f}
done
Using this corrected version appears to have resolved my SElinux issues, with the caveat that I have also added various SElinux policies as well, so at the moment it isn’t clear if the above commands are sufficient by themselves, or if the policies were also needed. I am going to research how to “undo” the SElinux policies and will report back with what I find.
Follow-up.
I was able to remove the custom SElinux policies and perform a backup with no apparent issues.
I will mark my prior post with the corrected “semanage” commands as “the solution”.
I just wanted to say after a fresh setup on Rocky Linux and enabling duplicati as a service I had all kinds of issues until I set the mentioned selinux permissions. This resolved my issues. Thanks for finding this.
In particular I was getting errors resolving to the oauth service with a permissions error and it suggesting me to generate a new auth id, which wasn’t the issue. Just for anyone else the runs into a similar issue.
I just ran into this after upgrading to openSUSE Leap 16. Not only did it fail to connect to my Backblaze B2 destination (helpfully providing an error: Permission denied (api.backblazeb2.com:443) ), it failed even to connect to updates.duplicati.com to check for updates.
The semanage commands listed at Package options | Duplicati didn’t work for me either, but the for-loop version provided by jberry02 did.
Fedora 43 here, sorry to necro this, but given the instructions here are wrong, I wanted to suggest the command that worked for me with a single rule:
semanage fcontext -a -t bin_t '/usr/lib/duplicati/duplicati(.*)?'
Would be good if the duplicati team updates that page.
Hi @Tama, welcome to the forum :waving_hand:
Thanks for the fixed command. I have updated the docs now.
